Author Topic: G Valve - Diverter Valve  (Read 5907 times)
Offline joesgti
Re: G Valve - Diverter Valve
« Reply #10 on: 12 August 2008, 10:24 »
just go with forge,  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
Offline neg
« Reply #11 on: 12 August 2008, 10:38 »
main dealer or somewhere like VAGPARTS
I have a Forge in my garage still from when I took it off - not has time to put it back on and since the G seems to be holding up well I dont know if I can be bothered now...
Offline pridders
  • Pearl Black 5 Door DSG GTI 05
« Reply #12 on: 12 August 2008, 10:59 »
I thought the whooshing noise was normal? I have noticed it more since I got my Revo Stage 1 a few weeks ago and was advised by the Revo dealer that I the car was not making full boost and this was more than likely down to the DV valve. I purchased the new 'G' valve from the dealer and I am getting it fitted today so hopefully when I take it to JKM on Friday the will tell me I am getting full boost. I will take some pics of the old valve and post them here later.
On the same note, I have noticed that since Revo Stage 1 between 3000-4000 RPM I am getting a whining noise, I think it’s the turbo or might even be the DV valve on its way out. Any one else had this?
Offline vRStu
« Reply #13 on: 12 August 2008, 11:28 »
Sell the Forge and do the relocation mod Neil  :grin:
Stu
Offline neg
« Reply #14 on: 12 August 2008, 11:30 »
You just like spending my money!  I might sell the Dbilas and relocate instead...
Offline synnea
« Reply #15 on: 12 August 2008, 11:54 »
Wheres the best place to buy a forge DV Valve? Are they easily fitted?
R32 : DBP : Lux Pack : Winter Pack : Cruise : Leather : Parking Sensors : Rear Tints : Armrest : RNS 510 : Ipod MediaIn : FreeView Tuner : VagCom
Offline vRStu
« Reply #16 on: 12 August 2008, 11:58 »
You can buy directly from Forge or via the network of dealers.
You need to remove the existing Diverter from the turbo housing and fit the forge one, then run the vacuum source to the forge valve.
In true Haynes fashion probably 2 out of 5 spanners for difficulty depending of course on your abilities.
Stu
Offline synnea
« Reply #17 on: 12 August 2008, 12:04 »
The GTI I am about to buy has a swoosh noise under acceleration - is this normal? It has been remapped.  My remapped GT TDI has the owl noise and this is normal from the turbo. I assumed when I test drove the GTI the swoosh noise didnt mean anything wrong......but mentioned earlier dubaiphil thinks his dv valve is on the way out..could this be the case with the GTI I am about to buy? It has just been serviced as well so I assume all should be well.
« Last Edit: 12 August 2008, 12:06 by synnea »
Offline vRStu
« Reply #18 on: 12 August 2008, 12:08 »
DV's fail even on stock cars, the later revisions have helped and the G version seems to be much better.
Stu
Offline synnea
« Reply #19 on: 12 August 2008, 12:11 »
ok - ill just drive away at her and I can deal with it at the time if it fails.
