Author Topic: Water in passenger footwell?  (Read 67446 times)
Offline T_J_G
Re: Water in passenger footwell?
« Reply #20 on: 20 September 2008, 20:29 »
I've noticed a bit of water in the rear passenger footwell, but I can't find these nipsters. Could anyone post a pic or describe exactly where they are? I've followed the description on here, but can't make it out. Cheers.
Do you have a sunroof? I think it's for sunroof cars only...open the front doors and look above the door hinge and they'll either be some nipples or a round black circle blanking plate 2-3cm round.
If not check the pollen filter (though I doubt it's that) and check your rear pillars see if the rear washer feed is leaking.
Offline Ant1981
  • Feed me, prod me
« Reply #21 on: 20 September 2008, 23:15 »
No sunroof, but I'll check the pillars and see what's occuring. It's a 5 door if that helps.
'09 Kawasaki Ninja ZX-6R
Offline T_J_G
« Reply #22 on: 21 September 2008, 09:54 »
I don't think you'll have the nipples so points to rear washer feed leaking or pollen filter (doubt it is this one). Or possibly the drainage behind the rear bumper is jammed shut.
Offline Ant1981
  • Feed me, prod me
« Reply #23 on: 21 September 2008, 11:38 »
This rear bumper drainage, where exactly on the bumper should I be looking?
Offline richw911
« Reply #24 on: 21 September 2008, 22:54 »
http://uk-mkivs.net/forums/p/51109/392618.aspx#392618  :wink:
Offline Ant1981
  • Feed me, prod me
« Reply #25 on: 22 September 2008, 07:07 »
Thanks. Had a read, they all seem to have water in their spare tyre bay, rather than the floor though.
Offline lugzy
« Reply #26 on: 13 May 2009, 19:10 »
im having the same problem but its damp not socking so i think its only just starting but i only get it in the back foot wells n i cant find this nipple ur ona bout on the door is there n e chance u could post a photo or send me a photo of where it is located cause i really dont want it to get bad thank youu
Offline T_J_G
« Reply #27 on: 13 May 2009, 19:24 »
You only have the nipples if it's got a sun roof I think. I'd check the drainage behing the rear bumper as per the link above.
Offline lugzy
« Reply #28 on: 14 May 2009, 12:49 »
okies then ill look after work then
Offline mac456
« Reply #29 on: 02 September 2009, 15:10 »
another guide for replacing the polen filter, goes more in depth
http://forums.vwvortex.com/zerothread?id=968305
