Author Topic: Power steering pump  (Read 786 times)
Offline bundy
Power steering pump
« on: 11 August 2008, 01:03 »
how easy is it to change the above on an 8v? anything i need to watch out for?
Re: Power steering pump
« Reply #1 on: 11 August 2008, 08:59 »
have a look for threads on doing the pas belt, that'll tell you where all the many bolts are to loosen the pump, then you just loosen them a bit more till the pump comes out :grin:
its not particularly difficult just that there are loads of bolts that need undoing before it will come loose, and some are pretty well hidden.
Offline bundy
« Reply #2 on: 11 August 2008, 18:31 »
ok then lovely job, will a pump from a G6o fit an 8v?
« Reply #3 on: 11 August 2008, 18:32 »
it has a different part number so i would guess not!  any other mk2 one will fit tho
