Cosmetic and bodywork matters
PAINT DAMAGED BY RUBBER
Topic: PAINT DAMAGED BY RUBBER (Read 9663 times)
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re:PAINT DAMAGED BY RUBBER
Reply #10 on:
22 June 2004, 12:15 »
Didn't damage my paint when I removed the red & silver GTI strips off my replacement door. I think it can damage rubber though, or was it silicone??
Fielder5757
Guest
Reply #11 on:
22 June 2004, 13:19 »
Seems to be working, Ive got one 1/4 pannel clear of any sh!tty sticker glue
Just another 7 pannels to go
nogama3
Guest
Reply #12 on:
22 June 2004, 14:21 »
just use trusty old t-cut. it should take off the tyre marks. my mate had the same problem when his tyre burst and left scuff marks all over his wing. Or if if is a pain then use some cutting compound from halfords etc.
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Reply #13 on:
22 June 2004, 16:20 »
As nogama3 said, try some rubbing down compound from any car accessory shop, it is quite abrasive but if you use it gently and then use a good polish afterwards it should take off the rubber. I used it recently to take the tar spots off the side of my car, then I used a cut and shine polish afterwards and it worked a treat.
......now officially dubless.
VR6_ROB
Mk2 VR6 / Corrado G60
Reply #14 on:
22 June 2004, 22:29 »
use a bit of petrol that did the trick on sticky stuff off the ax
rubjonny
10k hero
Reply #15 on:
24 June 2004, 11:34 »
Did you put a match to it after?
Sorry couldn't resist, my girlfriends AX has been driving me up the wall, the AA wanted ?750 to fix it, I got the parts for about ?80. Bloody ripoff merchant garages
