Author Topic: coil overs fitted now i have the shake's, help!  (Read 2739 times)
Offline ady365d
Re: coil overs fitted now i have the shake's, help!
« Reply #20 on: 19 August 2008, 20:54 »
cheers knight rider il see if i can have a look , not sure how to get to it easily tho? its sounds like this could be the prob as its like theres play in the rack when i move the wheel left and right the track rod also moves as it it should so its not the ball joint it might well be the other end !!
Offline ady365d
« Reply #21 on: 25 August 2008, 22:25 »
had a quick look at the inner track rod end today , well tried too cant really see how to get to that easy?? anyone??
had another thought tho maybe engine mounts ?? as it seems to only do it under acceleration and not when coasting ???
probably a combination of a few things i recon i dont think it's because of me slamming it , i recon its a fault thats been there for a while but as iv put the new shocks on its highlighted it and as its so low its more sensitive so the problem is magnified!
what you recon??
Offline bored_Welsh_lad
« Reply #22 on: 26 August 2008, 14:31 »
Could be mate, has your camber and toe been set up correctly too
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
