Author Topic: Loss in Power, Advice needed.  (Read 5198 times)
Offline RedRobin
Re: Loss in Power, Advice needed.
« Reply #10 on: 11 August 2008, 18:04 »
Is the diverter valve or dv known under any other name?  I have rang about 4 different garages, including 2 vw dealers in Northern Ireland and none have heard of either.
.... :shocked: That's plain stoooopid!! They simply don't deserve to represent VW. I would complain to VW UK (or equivalent in NI).
Offline ub7rm
« Reply #11 on: 11 August 2008, 19:31 »
I remember having the same problem trying to tell the parts guy at vw that i wanted a dv for my mk4.  Eventually I showed him what it was on a diagram.  The official name turned out to be something like a bypass valve  :undecided:
2020 BMW 128ti
2017 Golf GTD Estate
Offline RedRobin
« Reply #12 on: 11 August 2008, 19:38 »
....Well, my VW dealer knows what I mean when I say Diverter Valve. I've even seen it called that on some VW documents.
Offline vRStu
« Reply #13 on: 11 August 2008, 19:44 »
Doesn't matter what it's called, I gave you the part number  :rolleyes:
However as you are concerned, it's called a 'Cut Off Valve' - They still won't have a clue what you're talking about though.
Stu
Offline keyser
  • They're only the band the beatles could've been.
« Reply #14 on: 11 August 2008, 20:41 »
Thanks for the PN Stu.  I'll call at the dealers tomorrow and get it sorted.
MK5 GTI, manual, silver, dirty pipes.
Offline Teutonic_Tamer
« Reply #15 on: 11 August 2008, 22:09 »
It's actually called a Recirculating Valve - but the part no should have bought it up on ETKA.
Is there really any such thing as a "good" VW stealer?  :angry:
I feel like a homo
Offline vRStu
« Reply #16 on: 11 August 2008, 22:24 »
They do call it a Cut Off Valve these days TT  :nerd:
Dunno why they have to keep changing the names of these things.  :undecided:
Stu
Offline stevieC
« Reply #17 on: 11 August 2008, 22:38 »
The same thing happened to me after getting a Revo map,ran great for 2 days then total loss of power when on boost.first i thought it was the forge D.V but it was ok,then i booked into VW and they said it had a bad misfire on piston 2 so they changed no.2 injector and the fault was still there.After a week at the dealers it ended up being the ecu which was replaced under warranty.
Gtd 3dr candy white,charleston shadows
Offline RedRobin
« Reply #18 on: 11 August 2008, 23:03 »
....Have you gone back to a Revo remap?
Sounds as if you were lucky getting a new ECU under warranty when you had remapped the original one! :shocked:
Did the Revo tuner you used, firstly check your car for status/faults, then use a rolling-road and also finally drive it with a laptop attached?
Offline joesgti
« Reply #19 on: 12 August 2008, 09:43 »
hey, sorry for the late reply, ive been in ibiza for abit  :cool:
my problem: took to awesome and put in on the rollers and only ran 200bhp, took it back to awesome afterwards for a diagnostics and found then my hoses around the dv had spit and was loosing 8psi of boost. so changed the hoses and ran it againg and its then ran 230bhp......still down  :sad:. so back to awesome for diagnostics and vagcom had no faults and also no leaks under the hood but we did find that the car was not boosting past 4900rpm, so called up the re-map guys and they sent somebody up to have a check of the car, he took off the map and re-applyed a (in his words) "more aggressive map."
took the car out and its sorted, i knew it was mended once i hit the fast pedal!!!! :shocked: just need to get on the rollers now,
anybody facy a small do at awesome :wink:
GTI MK5
Not the only GTI...........but the best! ; )
