Author Topic: Seat possbilities?  (Read 2845 times)
Re: Seat possbilities?
« Reply #10 on: 11 August 2008, 15:50 »
I dont think the subframes are actually the same, but they are the same height :)
I always forget when i climb into my mates mk2 its quite a fall if you arn't prepared  :grin:
edit: oh and another thing, if you have pre-90 MK2 GTI seats and want em lower without having to change/loose the std pattern, you can use a MK3 Polo GT/G40 (i.e. one with bolsters) driver seat base frame, it fits all the pre-90 MK2 fabric/foam perfectly and is lower :)
If you dont have bolsters a low spec Polo MK3 base will do, or you could get a low end spec seat and chop/weld your old bolster frame to it.  Some late MK2 polo bases may work, but I think they have the forward/back handle on the wrong side a la MK1.
And make sure its a height adjustible frame, the non height adjust ones have the rear legs at the wrong angle to fit a MK2 well, I had one on my MK2 for a while (was from a LHD polo GTpassenger seat) I bent the legs so the seat would fit but it didnt slide in the rails very well.
« Last Edit: 11 August 2008, 15:55 by rubjonny »
Offline bomp
« Reply #11 on: 11 August 2008, 16:15 »
Forgot to mention, that I swapped the stubby rocco tilt knobs for Golf MK2 ones, as they stick out further to hold the seat belts.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline Mew
« Reply #12 on: 11 August 2008, 20:59 »
Just to confuse things further, couldn't you use a scirocco frame with pre-90 mk2 foam and fabric?
Offline JC
  • Back in the North.
« Reply #13 on: 11 August 2008, 21:04 »
noooooooooooooooooooooooooooooo
i is confused now
what seat / frame combo will get me LOWEST in the car - its a 90 spec 5 door as my heed hits the roof al the time  :undecided:
« Reply #14 on: 11 August 2008, 22:22 »
No I dont think so, afaik all the rocco frames are different to MK2.  Maybe MK1 rocco?
i is confused now
If you want to keep your oem seats youre out of luck! if you dont mind swapping then Scirocco or Corrado seats, or pre-90 MK2 seats with Polo MK3 base frame :)
