Author Topic: Fitting Mk4 chip ??  (Read 1798 times)
Offline stmirren
Fitting Mk4 chip ??
« on: 04 August 2008, 20:38 »
Found this link on e-bay, looking for some advice on the possibility of fitting the chip personally, I fitted a chip on my Fiat Coupe that was not to difficult, but like anything you never really know. Has anyone done a self fit and what are the possibilitys of it going wrong etc. (obviously I am trying to save money ) Cheers in advance
http://cgi.ebay.co.uk/Performance-mod-Chip-for-VW-Golf-1-8-Turbo_W0QQitemZ250277202439QQcmdZViewItem?hash=item250277202439&_trkparms=72%3A988%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318
Offline Rhyso
Re: Fitting Mk4 chip ??
« Reply #1 on: 04 August 2008, 20:39 »
welcome and avoid like the plague
have a search for better options and more reliable companies :afro:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #2 on: 04 August 2008, 20:54 »
The chip in question would be a PSOP44 surface mount type. To remove the old chip you need to use a hot-air rework station, if you try to remove with soldering iron you will pull and the pads away from the PCB.  The main problem with these chips is knowing what your getting. For 1.8T engine there are well over 1000 hardware and software combinations.  You wont know for sure what the software version is, the only was to tell is the read the full flash from the ori chip using OBD remapping tool or read the chip direct in a programmer.  wrong flash file will = a no running car, or ECU ROM error.
IMO too much guess work and too many risks.
But with the correct tools the right skills, and the matched SW and HW file with the right checksumm then you might be fine.
below is what they will send you...
this last picture it of a remapped chip which has been refitted.
« Last Edit: 04 August 2008, 20:56 by RTechUK »
 01455 617233
Offline Rhyso
« Reply #3 on: 04 August 2008, 21:09 »
slightly off topic
Nick - did you get my PM about the actuator?
Ta  :smiley:
Offline richw911
« Reply #4 on: 04 August 2008, 22:16 »
As said really find reliable companies like R-tech you can send the ecu to nick to save a bit of money......
Offline RTechUK
« Reply #5 on: 04 August 2008, 22:26 »
slightly off topic
Ta  :smiley:
PMd You.  Plus found 5 pages of past PMs lol I think the forum down time knocked me of track.. :huh:
Nick
 01455 617233
