Author Topic: Opinion's please  (Read 4675 times)
Offline Top Cat
Re: Opinion's please
« Reply #30 on: 05 August 2008, 14:33 »
I,d want to do it out of 0.9,stick GTI in whever you wanted it and Topcat,which bits you sanding down to fit???..
When it sit's inproperly i'm presuming that it is supposedl'y sits in flush with the alu look surround's. It is tight in acouple of places so i think iv'e got to sand the inner edg'es of the rev counter side
Offline cняis
« Reply #31 on: 05 August 2008, 14:35 »
i blinged my rover in a similar way, was brushed stainless steel and didnt cause any reflective problems
be careful of the double sided adhesive, the cockpit will get very hot and no doubt make the glue come unstuck, i had this happen to me  :huh:
cost about £20 off ebay
Offline Gulfstream11
« Reply #32 on: 05 August 2008, 14:40 »
Be careful when reworking,make sure you follow the grain which would become a pain when sanding the top of the arc.I,d just reduce the rad until it fits perfect.What was wrong with the inserts for you to remove them and wot you ordered from VW??  :rolleyes:
Previous rides..MKIV 1.8T   MKIV PD150  MK5 GTI MK5 edition30 now MK7 GTI PP
Offline Top Cat
« Reply #33 on: 05 August 2008, 14:52 »
sorry for the delay my connection just went down.
Quote
.What was wrong with the inserts for you to remove them and wot you ordered from VW??  rolleyes
OK i'm confusing things here i have recaro seats and for a while now have been trying to change these insert's for some alu one's see below. could not figure out how to take them out but i have ordered a spare one and this will show me how it connect's to the back clasp and also i then can show you it and see if you can make them for me out of alluminum  :huh:
« Reply #34 on: 05 August 2008, 14:59 »
Ahaaaa.. I remember now.
Offline Top Cat
« Reply #35 on: 05 August 2008, 15:01 »
Do you think you can make them i have been working on this mod for ages and must get it done somehow  :lipsrsealed:
« Reply #36 on: 05 August 2008, 16:11 »
Is it the full handle,if so it needs developing flat with comp for bends,then folding.Can be done I reckon but I need the unit removing from the seat for accurate measurement.I reckon thats gonna be a right ball ache.
