Author Topic: Good MPG?  (Read 4882 times)
Blue MK2
Re:Good MPG?
« Reply #10 on: 01 May 2004, 11:43 »
i get about 32 in town :o
Offline tinman
Re:Good MPG?
« Reply #11 on: 01 May 2004, 11:52 »
after the car was tuned and serviced i'd see around 43-45mpg at 60. around town it never really dropped much under 28mpg.
i do remember seeing it at 1.6mpg, ahem, but then i did have it maxed out on an autobahn.
one thing i do know is that the sensors seem to start breaking down. mine currently says around 8mpg regardless of what i'm doing, and i know its in the high 30s.
if anyone actually knows where the sensor is, drop us a line :)
Veedubgt18v
Re:Good MPG?
« Reply #12 on: 02 May 2004, 20:49 »
if i drive really boring ly mine sometimes says 49  :o
Veedubgt18v
Re:Good MPG?
« Reply #13 on: 02 May 2004, 20:50 »
tin it works on vacuum, there should be a vacuum line somewhere on the inlet manifold that you can trace to the bulk head, it may have fallen off or something. failing that the mfa could be on the blink ($$$$$$) :o
Offline tinman
Re:Good MPG?
« Reply #14 on: 03 May 2004, 12:18 »
interesting you say that. cause it has another problem that we think is either a missing vacuum hose or an air leak.
any idea where this hose is?
Veedubgt18v
Re:Good MPG?
« Reply #15 on: 03 May 2004, 12:22 »
on an 8v i do its on the right hand side of the inlet manifold, where the brake servo vacuum pipe goes aswell. follw the vacuum pipe from the servo to the inlet manifold and it should be there. hold on let me see if i can find a picture then you can see what im on about
Veedubgt18v
Re:Good MPG?
« Reply #16 on: 03 May 2004, 12:36 »
here ya go its an 8v but the principal should be the same
You see that bit i have outlined, the yellow valve in that which is inline in a pipe, well the little vacuum line coming off immediately behind it is the bit that the mfa takes its reading from.
Veedubgt18v
Re:Good MPG?
« Reply #17 on: 03 May 2004, 12:38 »
thats on a left hooker, so the brake servo maybe on the other side,if that little pipe isnt connected it can let unmetered air into the engine a cause  dodgy idle etc
Offline tinman
Re:Good MPG?
« Reply #18 on: 03 May 2004, 12:49 »
if the rain stops i'll go wake it up and take a picture.
tin
Veedubgt18v
Re:Good MPG?
« Reply #19 on: 03 May 2004, 12:52 »
yeah ok im not sure what its like on a 16v but its gotta be a similar arrangement, let us know how you get on!
ed
