Author Topic: 2.0 running sluggish  (Read 4904 times)
Offline Madmax
Re: 2.0 running sluggish
« Reply #10 on: 30 July 2008, 20:15 »
Will do.
Thanks a bunch.
Offline richw911
« Reply #11 on: 30 July 2008, 20:16 »
Will do.
Thanks a bunch.
No probs bud this is what this forum is all about  :cool:
Offline Rhyso
« Reply #12 on: 30 July 2008, 20:49 »
just a word of warning that no code readers or VAG COM can pick up an intermittent MAF fault - they're absolute buggers to diagnose  :angry:
common fault is flat spots through the rev range and diminishing fuel economy
Offline richw911
« Reply #13 on: 30 July 2008, 20:51 »
Yeah thats very true. Could also be the lamba sensor i know mat has had two on his 2.0 since he has had it.
Offline richw911
« Reply #14 on: 30 July 2008, 20:55 »
You could also try unplugging the maf to see if it runs better  :wink:
Offline Jamm89
  • Mk4 GTI 2ltr 3door Black
« Reply #15 on: 30 July 2008, 21:15 »
A throttle body clean wouldn't go a miss as well  :wink:
Worked wonders on mine.
Offline richw911
« Reply #16 on: 30 July 2008, 21:16 »
http://uk-mkivs.net/forums/p/127279/857711.aspx#857711  :wink:
Offline Madmax
« Reply #17 on: 30 July 2008, 22:26 »
Slow down a bit guys. :grin:
What does uplugging this 'MAF' do. Thanks for that guide Rich, will give it a try tomorrow, is there an alternative to using carb cleaner tho?
 :smiley:
« Last Edit: 30 July 2008, 22:29 by Madmax »
Offline richw911
« Reply #18 on: 30 July 2008, 22:33 »
 :smiley:
If you unplug it and it runs better you have a faulty maf (put the code reader on it first as unplugging it will thow up a fault code). No use carb/intake cleaner.  :wink:
Offline Madmax
« Reply #19 on: 30 July 2008, 22:38 »
Brilliant. :smiley:
