Golf mk3
hardmonkeys
changing radiator.
Topic: changing radiator. (Read 743 times)
beni-iow
changing radiator.
30 July 2008, 13:19 »
can any one tell me how hard/how to change a rad on a gti 8v its the main rad not the aircon one as mine is starting to seep from the bottom right corner
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Re: changing radiator.
30 July 2008, 15:31 »
Its quite easy, take the front bumper off.. Im not sure about one with A/C i dont know if you have to move the A/C rad but i just took the front cross member off, took four 10mm bolts out of the rad and disconected the hose, simple as that.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Paul86S2
30 July 2008, 16:14 »
As answered but you will also need to take the 4 bolts off the aircon rad that attach it to the main rad and angle it out of the way. Be carefull its easy to split the pipes or connections.
Paul
Golf mk3
hardmonkeys
changing radiator.
