Author Topic: Best recirculating valve for the 1.8T.  (Read 159822 times)
Offline Rhyso
Re: Best recirculating valve for the 1.8T.
« Reply #10 on: 20 February 2009, 15:05 »
so what problems do people experience with the splitter then?
engine management light / loss of boost and performance
Offline davetec-s
« Reply #11 on: 23 June 2009, 23:19 »
i got a splitter valve on my AUM which everyone says you shouldnt do but i havent had any problems! I havent experienced loss of boost as i took the trumpet off and put the blank plug in to change it to fully re-circulating an if anything it felt slower??!!! makes an awesome tssshhhhh with an induction kit too :P
Offline Payne
« Reply #12 on: 03 September 2009, 13:55 »
fitted my 007P today  :grin:
It cost me 5 minutes work
« Last Edit: 03 September 2009, 16:04 by Payne »
Offline dubmad
  • dubs all the way
Re: Best recirculating valve for the 1.8T.for the 1.8T.
« Reply #13 on: 11 March 2010, 18:53 »
is there a bit more info on fitting a recirculating valve for the 1.8T.agu engine. as my engine looks diffrent to the one on this thread. the last owner tryd fiitting a non recirculating valve.
and
« Last Edit: 11 March 2010, 18:56 by dubmad »
http://
Offline barry-gti
« Reply #14 on: 11 March 2010, 20:29 »
WTF is going on in your engine bay  :grin:
Looks like he's just relocated the DV to the cold side. the two pipes that are plugged are where the original Recirc DV would go...
Offline dubmad
  • dubs all the way
« Reply #15 on: 11 March 2010, 23:27 »
 would this fit think its a early forge oo7p and how would u fit it and sort the mess out.???thanks
http://
Offline barry-gti
« Reply #16 on: 12 March 2010, 07:14 »
yeah that would fit. u know how it goes?
Offline dubmad
  • dubs all the way
« Reply #17 on: 12 March 2010, 09:10 »
hi, no i avent a clue???? im looking for a bit of help thanks.
http://
Offline barry-gti
« Reply #18 on: 12 March 2010, 10:01 »
From what i can see. you'll need to put the bottom part of the Forge DV into the plugged hole on the turbo intake pipe, then you will need to source an original hose from where the blue plug is and plug it onto the side of the DV. then you'll need to put the blue vacuum hose onto the nipple at the top of the DV (where it already is) and then plug that hole where he's relocated it...
Offline dubmad
  • dubs all the way
« Reply #19 on: 12 March 2010, 12:03 »
do you mean some thing like this
i have seen most dv fitted on the front of the engine as on this thread. thanks
http://
