Author Topic: Center Console re-spray  (Read 4825 times)
Offline GTi-Matt
Re: Center Console re-spray
« Reply #10 on: 27 May 2008, 17:49 »
that sounds easy enough to do, might have to have a go at this mines all scuffed duno how the previous owner did this.
what paint codes did u use to do this then mate?
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline Ridg
  • TDI - Soot Happens!
« Reply #11 on: 27 May 2008, 17:51 »
Have you done the matching wood trim on the doors?
i started doing them, but hadn't masked the finger plate properly and ended up spraying part of the rubberised surface silver so just swapped them out for the standard, with the intention of sorting it later. below are a couple of pics of what the handles i finished look like.
dubbz, i got pretty much everything from halfords, primer, silver reflex paint, lacquer, assorted wet and dry.  I bought 2 of each, but you could probably do it with 1 as i was planning to do the door handles too.
in addition to the paint i bought some gloves, masking tape and breathing mask from wilko
can't see any reason why it wouldn't work on the standard black, you just need to rub it down to a surface you can bind the primmer to.
Offline GTi-Matt
« Reply #12 on: 27 May 2008, 18:00 »
door handles look smucking fart mate :afro:
have u got any paint codes mate? sorry to pest
Offline Ridg
« Reply #13 on: 27 May 2008, 18:11 »
yeah just a shame i fooked up the finger plate, if i can find a second hand one, i'll re-do it as i doubt the over spray is going to come off without damaging the rubberised bit, plan was to just spray the wood part of it.
re paint codes, i used the spray cans, so literally bought the off the shelf reflex silver, if you've got a gun then you would need them at which point you'll have to ask someone else lol
Offline GTi-Matt
« Reply #14 on: 27 May 2008, 18:17 »
ok mate, thats cool will have to get down to my local halfrauds and get me some, hope i get the right stuff. how long did it take u in total then mate?
