Author Topic: 2.0 8v into mk2 1.8 8v  (Read 7914 times)
Offline Zoid
Re:2.0 8v into mk2 1.8 8v
« Reply #20 on: 02 May 2004, 21:52 »
From what I've read the conversion to the existing 1.8 block is normally either to 1.9L or 2.0L, firstly the standard bore is increased from 81mm to 82.5/83mm, and then to get to 2L you need a new crank for a longer stroke. I'm guessing now but generally if you choose to use a different bottom end the majority of advice seems to point to 2L short blocks i.e. Audi 3a, early mk3 2e, which I assume has both an increase bore and stroke and also has no clearance issues when fitting into the Mk2.
This is a conversion I'm thinking about having done later on, however it's costly as to get any decent power gains on the 8v you'll need a fair bit of head work in order for it to breathe properly...
« Last Edit: 02 May 2004, 21:54 by Zoid »
golfvr6
« Reply #21 on: 02 May 2004, 22:21 »
You will get a very good increase without head work, obviously head work would be better!
There is no substitute for cc  ;)
trustno1
« Reply #22 on: 02 May 2004, 22:55 »
mmmn so now we've gone from an 1.8gti 8valves 2 a 2L LOOOOOL   :D this is never gonna end  :D :D
marcus123
« Reply #23 on: 02 May 2004, 23:08 »
you got your golf yet mate?
trustno1
« Reply #24 on: 03 May 2004, 00:41 »
na not yet mate,  :-\ oh well  :)
