Author Topic: Vag com errors! intresting!  (Read 1468 times)
Offline MaXXeH
  • Golf MK5 GTI
« on: 20 May 2008, 18:59 »
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
   Controller: 06A 906 018 CG
   Component: 1.8L R4/5VT MOTR HS D02
   Coding: 04000
   Shop #: WSC 00000
2 Faults Found:
00543 - Maximum Engine Speed Exceeded (Engine Warranty VOID! :-)
            35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes
   Controller: 1J0 907 379 Q
   Component: ABS/EDS 20 IE CAN  0001
   Coding: 13504
   Shop #: WSC 01317
No fault code found.
Address 08: Auto HVAC
   Controller: 3B2 907 044 C
   Component: CLIMATRONIC     C 0.7.0
   Coding: 01000
   Shop #: WSC 01317
Skipping Address 15-Airbags
Address 17: Instruments
   Controller: 1J0 920 921 A
   Component: KOMBI+WEGFAHRS. BOO V28
   Coding: 05442
   Shop #: WSC 00000
   Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1626273
Address 19: CAN Gateway
   Controller: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
Address 46: Central Conv.
   Controller: 1J0 959 799 AH
   Component: 4V Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 01317
3 Faults Found:
01135 - Interior Monitoring Sensors
            36-10 - Open Circuit - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
            35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
End   --------------------------------------------------------------------------------------------------
i like the Maximum Engine Speed Exceeded (Engine Warranty VOID! :-) lol
