Author Topic: fuel pump doesnt stop running  (Read 4133 times)
Blue MK2
Re:fuel pump doesnt stop running
« Reply #10 on: 27 April 2004, 22:03 »
pukka
how much do these amps and ECU's go for as i have a few spare ;)
Offline richandhazel
« Reply #11 on: 28 April 2004, 11:16 »
Suggest you have a look on ebay see what they are going for.......
Offline Dizzie
  • Make friends with your fast
« Reply #12 on: 29 April 2004, 14:32 »
during my skint phase I ran a X contact relay in the fuel pump relay spot after cooking 2 fuel pump relays. when you turned the key the pump would continue unlike it should where it just primes the pressure. it never actually flooded the engine though.
god bless the K-jet ;D
Mk4 Golf 150PD
Blue MK2
Re:fuel pump doesn't stop running
« Reply #13 on: 01 May 2004, 20:21 »
If the engine is flooding the injectors must be leaking or being opened. Disconnect the electrical connection to the injectors and see if it still floods. Also disconnect the ign amp as this is what triggers the coil and pulls in the pump relay, a faulty amp can trigger the coil, pump relay and injectors. Have seen a faulty ecu hold the injectors open also.
Steve.
spot on mate with the ECU ;)
let that be a lesson
just made 60 notes ;D
« Last Edit: 01 May 2004, 20:52 by Blue MK2 »
