Author Topic: New golf  (Read 2350 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: New golf
« Reply #10 on: 18 May 2008, 23:20 »
Hi!
Hello M8 welcome to the forum.
The first question from new 1.8T Gti owners is mainly "I want more power" lol. IMO Standard perfomance from the 150bhp GTI 1.8t is pants.
But once remapped the car should feel how you would expect a Gti to feel, loads of power and wheel spin  :laugh:.
Looking at your user name It take it you could be from Scotland??? if so there is a good company up there called Star perfomance who can remap and transform it into a propper Gti.
The Forge 007p and an induction kit with the alloy relocation pipe will work wel together, plus it will make a nice blow off sound which is amplified by the induction pipe. The Blow off type valves dont work well with the 1.8T engines.
Steer clear of boost controllers, once remapped the ECU will take care of the extra boost and Fuel to air ratios, A good remap should see you boost around 1bar.  Too much pressure when running a Boost controller can lean the engine and cause det and cause the limp mode kicking in.
A remap should take the engine  upto around 195bhp to 210bhp depening on your engine spec.  A good exhaust and de-cat will also free up the mid range power band and give you a few more BHP.
A standard 150bhp Golf 1.8T should easy do 135mph, if your flat out at 120mph you may have engine issuse which need sorting out before you start to remap and tune the car. your first port of call it to get the ECU read using Vagcom.
Regards
Nick
« Last Edit: 18 May 2008, 23:23 by RTechUK »
 01455 617233
Offline Scottish_Gaz
Re: New golf
« Reply #11 on: 19 May 2008, 01:19 »
hi mate, lovely piece of information. i am from scotland but i actually live in derby mate.
yes the car will only do between 120-130 flat out which was last week on way home from buying it.
You say i could have engine troubles, well there seems to be no sign of anything that could need attention.
i am a little mechanical minded and i know when something seems not too good and it seems to drive ok and smooth so not sure if there is a prob or not.
not really wanting to de cat it as im after a bit of reality of running it than just purely after performance, so i will be doing a remap as seems to be a big difference.
at the min, the car has a baileys blow off valve but all noise comes out of the induction kit for some reason (sounds like it anyways)
Offline RTechUK
Re: New golf
« Reply #12 on: 19 May 2008, 18:42 »
Hello.
A good remap alone should put smile on your face.
Is your bailey DV a re-circ type or atmos Blow off?
Nick
 01455 617233
Re: New golf
« Reply #13 on: 19 May 2008, 18:52 »
hi mate, i dont know the difference to be honest.
how much do you charge for remap for members on here?
