Author Topic: Faulty lights on dash. help please!  (Read 1745 times)
Offline drivebycar
« on: 17 May 2008, 09:58 »
Hey,
Basically i was driving the other day and my oil light started flickering, by flickering i dont mean like on off on off like its supposed to was like it was an electrical fault just on on off on on off off off on etc
Then it stopped doing it and next time i got in my car the temperature warning light was flashing, but thermostat reading was normal and had a look under the bonnet and felt coolant pipes and it was nowhere near hot. So drove home no problems.
Just wondering what could be causing the fault and where the best place to get the part would be?
Any help much appreciated
Ta!
Normal is getting dressed in clothes that you buy for work and driving through traffic in a car that you are still paying for - in order to get to the job you need to pay for the clothes and the car, and the house you leave vacant all day so you can afford to live in it.
Offline 1990golfgti
Re: Faulty lights on dash. help please!
« Reply #1 on: 18 May 2008, 16:46 »
hey, ive got a similar problem on mine,randomly and i mean randomly my oil light comes on with that annoying noise,i can be anywhere engine hot or cold,its really annoying as the oil and filters been replaced yet it still does it, its not loosing oil or anything.im tempted to just remove the bulb if thats possible or the fuse cos i check the oil regular anyhow.
Offline Jay
  • balding fat cvnt
« Reply #2 on: 18 May 2008, 21:26 »
Could be one of the sensors or oil pump thats faulty?
Offline Khare
  • The bear that khares
« Reply #3 on: 18 May 2008, 22:45 »
i had this awhile back and my temp and fuel needle would read 0. I jsut pushed the clock back into the dash with a firm push using the palm of my hand and it sorted it. I think it could be the cables behind the clocks are abit loose.
Offline drivebycar
« Reply #4 on: 19 May 2008, 13:08 »
Hi, nah already replaced fuel pump and both sensors. Temperature light is flashing constantly now, how annoying! Ill try giving it a push and see if that works  :grin: nice one
VeeDubGTI16v
« Reply #5 on: 19 May 2008, 16:53 »
thats to indicate low coolant, if it overheats i dont think it flashes!
Offline drivebycar
« Reply #6 on: 19 May 2008, 21:39 »
its a picture of a thermometer in water next to it?
Offline drivebycar
« Reply #7 on: 21 May 2008, 12:26 »
anybody have any ideas?
Ta  :smiley:
Offline Horney
« Reply #8 on: 21 May 2008, 12:30 »
Light on temp gauage is for low coolant and overheating. Check your coolant level is good. If it is and car is running at god temps then sender, wiring or clocks are faulty.
Oil light and buzzer. These are telling you you are running low oil pressure not that the oil is low! Get it checled PDQ. 99% of times this is a faulty sensor, wiring or clocks but is it worth taking the risks?
Why is it whenever people get warning lights they assume it's a fault with the light/sensor? They are there to warn you your car may be about to die! Check out the reason it flashes 1st and if that is ok THEN start looking into faulty sensors etc.
Nick
Offline drivebycar
« Reply #9 on: 21 May 2008, 13:26 »
Hi mate,
Nah only reason i thought electrical or sensor or somethign is because ive just finished rebuiling the engine so i know all the oil and coolant is fine, just had new oil pump/cooler/sensors all done so shouldnt be anything wrong with that. Just wondering if anyone had had it before.
Cheers for your input ill check it out.
Nice one  :cool:
