Author Topic: Just bought a Dbilas Intake  (Read 10446 times)
Offline bacillus
Re: Just bought a Dbilas Intake
« Reply #20 on: 21 May 2008, 17:54 »
K1 check to make sure the intake isn't touching the brake fluid resevoir as that may cause the pedal vibration you are experiencing.
Without traction power is nothing!
Offline K1
« Reply #21 on: 22 May 2008, 01:57 »
Thanks for the tip Bacillus... i think the pipe from the intake to the DV is touching the brake fluid resevoir. Will see if i can come up with a fix.
White Edition 30. Born 26th/June/2007. Highline, Xenons, IPOD+Armrest, Cruise Control. Dbilas intake, Forge short shift, GIAC fuel maps, Forge DV, Milltek Non-res Turbo back, Eibach pro damper, pro kit and anti roll bars. Black Monzas, Kenwood DNX5220BT, R32 Front n rear brakes
Offline joesgti
« Reply #22 on: 22 May 2008, 04:09 »
sorry but what benefits would this have over your carbonio? as i cant see it being very much? :huh: inductions really dont do much in bhp and speed difference except slightly better throttle. i prefere the look of the carbonio and wouldnt loose the engine cover to acomidate an induction kit. also why dont you come to the RR day, im sure awesome wont mind one or 2 more, it would be good to see more variations of mods to see which get better gains. what other mods have you done now K1  :smiley:
GTI MK5
Not the only GTI...........but the best! ; )
Offline joesgti
« Reply #23 on: 22 May 2008, 04:10 »
scrap the last question, i just looked at you sig  :tongue:  :cool:
GTI MK5
Offline deanjames
« Reply #24 on: 22 May 2008, 15:11 »
After much reading about intakes for my MKV i've decided I'd like to try the EVOMS kit, but can we get them in the UK?
I can find a supplier so if anybody can point me in the right direction i'd be much appreciated
Thanks
Offline deanjames
« Reply #26 on: 22 May 2008, 15:27 »
Thanks Bacillus
Ok before i take the plunge.
EVOMS intake or HPS Intake??
The HPS intake does look cool in silver, see below
Offline 182_blue
« Reply #27 on: 22 May 2008, 15:29 »
wont that just suck up hot air from the engine ?
Offline bacillus
« Reply #28 on: 22 May 2008, 15:51 »
yes it will but the air will soon get much hotter once it reaches the turbo...
the original ram vw design is actually very good but let down by the air turbulence induced by the air box/filter.
Offline K1
« Reply #29 on: 22 May 2008, 15:57 »
There is a definite improvement in power/torque over the carbonio. My car is remapped tho, so the difference may be more noticeable than just intake alone. The turbo spools up quicker, before when on a charge thru the gears with the Carbo, there would be a small moment of lag when selecting the next gear before the turbo gives its max before slamming you into the seat. So u always feel the swelling of the torque moment. With the new intake, its feels more like a NA car, i don't have to wait for the torque to swell up as it is there already if you know what i mean? I didn't notice that feeling before until i drove an S3. Each upshift feels great, whereas mine i had that laggy feeling before the torque catches up after the gear change.
The intake is definitely less refined tho, still more civilised that an open cone filter like the EVOMS i would assume. Open window and u can hear a whistling noise at certain rpm's, hit high rpms, back off the throttle and u can hear a 'psst' noise from the turbo/intake.
I wish i could keep the engine cover, but then again. I don't often hit shows etc.. so how pretty my engine bay is, is offset by the stronger performance  :grin:
Can't make it to the RR day, have to bloody work. Will try to get my car on the rollers when i go down to manc on the 15th of July.
