Author Topic: 16v turbo oil feed.  (Read 1972 times)
Offline swinny
16v turbo oil feed.
« on: 26 April 2004, 11:04 »
i need a oil feed/return for my turbo anyone know the best way?
Offline mk1
Re:16v turbo oil feed.
« Reply #1 on: 26 April 2004, 21:12 »
Take the oil feed from the top of the oil filter housing, you may have to fit a restictor depending on the turbo. Use a tdi sump as this has a fitting on it for the return and gives you a increased sump capacity ;).
Steve.
Offline swinny
« Reply #2 on: 27 April 2004, 12:46 »
are you using the stock airbox and injectors?what ecu? do you have to change the throttlr boddie...could u give me a list of best things to use and what will work best thanx
Offline mk1
« Reply #3 on: 27 April 2004, 22:18 »
Modified air box, Bosch motronic ecu with knock sensing
change the throttle body? why?,
list of the best things to use and what will work best?.
Every body does it differently, mine is a "custom" set up built by me, if you build yours it will be different to mine. What parts have you got already?.
Steve.
Offline swinny
« Reply #4 on: 29 April 2004, 13:03 »
get those things of what car?iv only got turbo,intercooler,  deconpression plate,pipework,k jet air box..i need a ex/manifold.what is a 3 bar map sensor?do i need it?i thought 16v didnt have a ecu?what else will i need to get it working thanks.....
