Author Topic: Arches, Widestuff, Etc  (Read 10415 times)
Offline lowgolf
Re:Arches, Widestuff, Etc
« Reply #10 on: 14 May 2004, 10:41 »
angle grinder is goming out over the weekend when 90's spec arches are going on  ;D
<br /><br />Yeah!!!
Blue MK2
« Reply #11 on: 14 May 2004, 17:24 »
you can get genuine G60 arches from GPC at only ?85 ;)
Offline g0ldf1sh
« Reply #12 on: 17 June 2004, 08:38 »
Hi
I have a MKII 8V which is on 9X16 on each corner!
I get a fair bit of scrubbing on the rear, fronts aren't too bad.
The cars booked into a body shop to get the arches sorted out on the 21st.  I'm getting the arches from VW direct (does anyone know somewhere cheaper?).  They say they'll cut away or flatten anything that needs to be sorted then bond the arches onto the body.  Then i can go lower again.
Hope that helps!  I'll let you know what happens when i get it back!
Nehmen Sie Keinen Ersatz an
VeeDubGTI16v
« Reply #13 on: 17 June 2004, 21:13 »
how much were the arches from vag?
Fielder5757
« Reply #14 on: 20 June 2004, 11:05 »
genuine VW G60 arches and skirts are little under ?220 from GSF.
Im looking for the body-coloured arches, My M3 Side skirts arive next week, And im just painting my New Mirror pods as we speek ;)
nogama3
« Reply #15 on: 22 June 2004, 14:52 »
siliconed my mates g60 arches on with large rivets on the bottom. used an angle grinder to get rid of any fouling on the arch + on the arches themselves. I'd be wary about using spacers unless you get proper ones likethe eibach ones with the corect bolts, otherwise can be very dangerous, i know, my wheel came off on a b road, bloody nightmare it turned out to be.
mates car has been dropped 60mm on koni coilovers.
Offline g0ldf1sh
Re: Arches, Widestuff, Etc
« Reply #16 on: 07 September 2004, 14:38 »
After much consideration about which set of wheels to leave on the car i've decided to go for the Brocks in 9 X 16 so the car will be in to the body shop next week to have G60's put on and most of the metal taken away!  I'll let you know how i get on!
