Author Topic: Light bleeper not working  (Read 2374 times)
Offline T_J_G
« on: 15 May 2008, 22:39 »
You know the beeper that comes on when you open the door with no ignition to tell you you're lights are still on.
Well mine has stopped working  :laugh: and it's annoying as i keep leaving my lights on.  :rolleyes:
Has the happened before to anyone , what should I check. The beep still works when i need diesel or windscreen washer bottle filling up.
Any ideas?
Car is a S reg GT TDi 110
Offline richw911
Re: Light bleeper not working
« Reply #1 on: 15 May 2008, 22:41 »
Faulty door module  :undecided:
Offline T_J_G
« Reply #2 on: 15 May 2008, 22:43 »
hmm i shall have a poke around in the morning.....really unsure tobe honest though. I only realised it after i left my lights on 3 times!
Offline richw911
« Reply #3 on: 15 May 2008, 22:45 »
Do you interior lights all work? Do the indicators flash every time when you lock it from the remote?
Offline T_J_G
« Reply #4 on: 15 May 2008, 22:48 »
Yep.
Offline richw911
« Reply #5 on: 15 May 2008, 22:50 »
Yep.
Oh -  :undecided: Could just be a faulty buzzer or loose wire  :undecided:
Offline T_J_G
« Reply #6 on: 16 May 2008, 12:06 »
investigated further:
-bleeper works for low fuel and low washer bottle
-interior lights work when door opened
-when locked the indicators DO flash.
Hmm..Would a fault code show up for this?
Offline GTi-Matt
« Reply #7 on: 16 May 2008, 15:10 »
wouldnt have thouht so u will have to the electrics tested mate
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline T_J_G
« Reply #8 on: 16 May 2008, 15:40 »
what a ball ache, trying to sell it aswell, though most people wont notice!
Is there a reset for the ECU or something, or maybe disconnect the battery for a bit and hope it works after. It stopped all of a sudden and for no reason  :undecided:
Offline Rhyso
« Reply #9 on: 16 May 2008, 15:46 »
does sound like a loose connection - have you looked behind the headlight switch?
turn it to 12o'clock and push in it should then pull straight out
