Author Topic: Lowering Springs or Lowering Kit?  (Read 2101 times)
Offline Rhyso
Re: Lowering Springs or Lowering Kit?
« Reply #10 on: 16 May 2008, 12:05 »
any links to this PW motorsport can't seem to find them on the bay
amazing what you can find if you search for Eibach  :tongue:
http://stores.ebay.co.uk/P-W-Motorsport-Ltd
Offline Matt_Mk4
« Reply #11 on: 16 May 2008, 14:00 »
Someone I used to work with mentioned to me that due to the weight of the Golf's, lowering it on just springs will increase the risk of snapping the springs on original shocks under pressure
Is this the case or is he talking a load of rubbish?
Offline Rhyso
« Reply #12 on: 16 May 2008, 14:11 »
if you buy quality products then i doubt such a thing would happen.
most springs are designed to work with your original dampers although i'm guessing your original dampers will be worked harder.
IMO its always best to change the springs and dampers at the same time  :nerd:
Offline GTi-Matt
« Reply #13 on: 16 May 2008, 15:02 »
Ive just lowered my car the bodging way costs nothing and i can get an idea of how low i can go with my car till it starts catching anywhere. I cut a coil off the rear springs and a coil and a half on the front, already had people saying my car looks wicked lower! I would not suggest its a permenant fixture coz the springs are very loose when car is jacked up. but it still looks the dogs
WTF, why would you do this.
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline N3VS X
« Reply #14 on: 16 May 2008, 19:15 »
just to see how low i can actually go i will not have these springs on long as im gettin a full spring and damper kit. i didnt want to go out and buy a spring and damper kit only to find out its too low, as i said in my first post it ant a permenant fixive dropped it 50mm and it doesnt catch and also looks good at that hieght and that was my only aim. :embarassed:
Offline richw911
« Reply #15 on: 16 May 2008, 19:19 »
I see but your ride height wont be evan and why not just ask on here and look at pics of other golfs thats have different ride heghts  :undecided:
