Author Topic: Any ideas on what these are and do?  (Read 1963 times)
Offline remapped
  • If you are going through Hell, keep going
Re: Any ideas on what these are and do?
« Reply #10 on: 12 May 2008, 00:56 »
can this  carbon canister, evaporative emissions thingy widget unit be taken off then ?? as it is in the way ware a cold air feed pipe can run :) ?
OEM(ish) G3GTi 8v5dr
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #11 on: 12 May 2008, 01:11 »
Yes, a fuel pipe goes in, and a fuel pipe comes out... just join em up  :wink:
They become efectivly usless after 100k miles anyway, Just watch what pipes ur connecting where  :laugh:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Mew
« Reply #12 on: 12 May 2008, 01:12 »
A is the dipped beam coil or something like that. To do with your headlights basically.
Offline bored_Welsh_lad
« Reply #13 on: 12 May 2008, 08:20 »
how f**king good am i to you
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
