Author Topic: Need new ecu  (Read 3673 times)
Offline admc6
Re: Need new ecu
« Reply #10 on: 07 May 2008, 21:45 »
Its becasue it has a damaged earth to it, and the auto electrician it went to see today said that my new problem was related.
He couldnt find anything else wrong with it, and the fact it likes to cut out when it warms up was a good indication
Offline Pete Taylor
Re: Need new ecu
« Reply #11 on: 07 May 2008, 21:58 »
sounds more like the ecu temp sensor to me. A diagnostic scan would be a lot easier than replacing the whole ECU!
Offline admc6
Re: Need new ecu
« Reply #12 on: 07 May 2008, 22:04 »
Its had a scan and it came back with no faults
Offline boneybradley
  • Back in a Mk3...
Re: Need new ecu
« Reply #13 on: 07 May 2008, 23:16 »
Can i add......you need the ecu,ignition switch assembly/transponder and key from the car its removed from as the later post 95 models has a coded key which needs to match the ecu...... unless you fancy moding the ecu?
Offline Kenny_1.6
  • it will be a GTi... some day... lol
Re: Need new ecu
« Reply #14 on: 08 May 2008, 03:00 »
Why do you need a new ECU exactly?
exactly what i was about to ask  :laugh:
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich. :D
Offline admc6
Re: Need new ecu
« Reply #15 on: 08 May 2008, 07:25 »
when you say moding, what do you mean?
Offline Pete Taylor
Re: Need new ecu
« Reply #16 on: 08 May 2008, 07:25 »
And only cuts out when it warms up? Change the ECU coolant temp sensor then
Offline admc6
Re: Need new ecu
« Reply #17 on: 08 May 2008, 08:33 »
It seems to. Its doesnt take long, You will get about 2 miles and then when you let the revs drop it cuts out.
Where is that located?
Wouldnt it come up with a fault?
Offline Pete Taylor
Re: Need new ecu
« Reply #18 on: 08 May 2008, 09:20 »
The ECU uses resistance as a measure of detecting broken sensors and faults. If you get an ABS fault it will be because it's detecting low signal (low resistance resistance). The problem with the ECU coolant temp sensor is the fact is works on resistance. If it completely and utterly breaks or it's unplugged it will throw up a fault. However, they tend to break down within certain resistance (or temperature) ranges and not show faults. They are extremely difficult to test, so just worth replacing.
The heat from the coolant changes the resistance in the sensor and relays it to the ECU which equates a fuelling level from the given resistance. Basically if it detects a low resistance (i.e detecting the engine is cold) it will up the fuelling mix to compensate. If it detects a high resistance (i.e engine upto temp) then it will lower the fuelling for maximum fuelling efficiency. Hence why the engine needs to be hot to control emissions when MOT testing
Offline admc6
Re: Need new ecu
« Reply #19 on: 08 May 2008, 09:25 »
How does that make it cut out when the revs drop to an idleing speed?
Where is the sensor located and how easy would it be to change?
