Author Topic: exhaust help and advice  (Read 1803 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: exhaust help and advice
« Reply #10 on: 08 May 2008, 23:00 »
Here is a cheap back box and what the seller sent me,
Dear lazylunatic,
.. here?s how it works.. (quite easy to fit)..
we supply the parts to fit these and they come with the CORRECT INLET DIAMETER FOR YOUR CAR so just need your make, model, year and engine size when making payment.. these fit by cutting through your exhaust pipe immediately behind the old back box, then removing the old back box and installing the new one by bending THE HANGERS THAT COME WITH THE NEW BACK BOX and connecting up either by welding or by using flexible steel exhaust tube and clamps which we can supply at additional cost as a FITTING KIT which is of the correct diameters and size for your particular car. cheers
Not worried about the piping, just use flexi stuff and loads of exhaust sealer/grease stuff. Securing it in place is the hard bit... any ideas.
Cheers all
LL ;)
Offline Mikester
  • Civic Type R
« Reply #11 on: 08 May 2008, 23:24 »
my backbox will be up for sale soon. Only been on the car a month or so. Brand new.
Offline dbs
« Reply #12 on: 09 May 2008, 19:02 »
what back box is it
Offline LazyLunatic
  • MK3 20VT Project
« Reply #13 on: 09 May 2008, 23:12 »
its of an ebay seller - "zorsts"
it is quite cheap, like £50 for back box + £15 P&P. Might be worth a try, cause if it dont fit there is a 7 day return policy, but you need to read it cause it sounds like they can worm their way out of giving a refund.
It is stainless steel, so wont rust.
Check out the link, you can look at all the details:
http://search.stores.ebay.co.uk/ZORSTS-STAINLESS-EXHAUST-SYSTEMS_golf_W0QQfciZQ2d1QQfclZ4QQfsnZQ5AORSTSQ20STAINLESSQ20EXHAUSTQ20SYSTEMSQQfsooZ1QQfsopZ1QQsaselZ330814560QQsofpZ0
LL ;)
