Author Topic: nosiy rocker's  (Read 2426 times)
Offline samco-jack
nosiy rocker's
« on: 23 April 2004, 18:21 »
Hello buddies,
                      my MK2 golf gti 8v has got a bit of a problem the hydrolic rockers are really really nosiy ,Does any one know the best thing to do about it .
cheers buddie,s
Offline richandhazel
Re:nosiy rocker's
« Reply #1 on: 23 April 2004, 18:54 »
Are they noisy all the time or just when you start up or during warm up?
When was the oil last changed? What oil filter do you have fitted?
Offline samco-jack
Re:nosiy rocker's
« Reply #2 on: 23 April 2004, 21:38 »
There nosiy all the time ,The oil was changed 2 weeks ago and the oil fillter is 100% spot on vw/audi one.
vwsystems
Re:nosiy rocker's
« Reply #3 on: 24 April 2004, 18:08 »
you could try some engine flush at next oil change....
or replace the whole lot at ?7 each. and you need 8 of them..........
have you taken it for a blast down the duel carrageway
do you high rev the car........
most people drive slow and dont rev the engine high so the oil never really covers the tappets this is what wears them out quicker! lack of oil........
Re:nosiy rocker's
« Reply #4 on: 24 April 2004, 20:15 »
Worth a go^^^^^, there is a test you can do to check if they are worn.......I'll see if I can find the info..........
golfvr6
Re:nosiy rocker's
« Reply #5 on: 24 April 2004, 22:24 »
Maybe worth getting the oil pressure checked.
You don't need to rev the engine for the oil pressure to pump up the tappets, so slow or fast driving will make no difference  :)
golfvr6
Re:nosiy rocker's
« Reply #6 on: 24 April 2004, 22:26 »
To test the tappets for wear,
Run engine to operating temp
Remove cam cover
turn engine over till the cam lobe on the tappet you want to check is pointing upwards
press down on the tappet
the tappet shouldn't move more than about 1mm
(I think)
 :D
Re:nosiy rocker's
« Reply #7 on: 25 April 2004, 00:21 »
 ;) I think you've got it there...........I was going to/have been trying to dig out the actual bentley script.........should have it for you later today
Re:nosiy rocker's
« Reply #8 on: 26 April 2004, 19:03 »
Better late than never ::)
http://www.richandhazel.servebeer.com/gti/mk2/Engine/main.htm
What you said is correct 'vr6 the only difference being that the tolerance is actually a lot smaller: 0.1mm or 0.04" in old money
Hope that helps.......
golfvr6
Re:nosiy rocker's
« Reply #9 on: 26 April 2004, 19:36 »
Yeah i thought it wasn't quite right  :D
