Author Topic: VAG COM  (Read 2369 times)
Offline flex
Re: VAG COM
« Reply #10 on: 07 May 2008, 00:10 »
I keep hearing about this VAG COM business. Is it worth investing in?
I have a Mac so would use my parents Laptop to do this.
What exactly does VAG COM do?
My car broke down not too long ago and i determined that the plugs were not sparking but had no real idea what was causing this. I bought exactly the same lead as this from ebay and installed the software on me laptop plugged it into the car and it gave me a pretty tidy little report listing any faults that have been logged in the ecu. Mine was a problem with the engine speed sensor which i then changed and the car has been sweet ever since.
If i had of taken it to a garage they would of charged me a lot more for the initial diagnostics so it was money well spent and i recommened getting one.
Here is an example of what the report looks like:
VAG-COM Version: Release  311.2-N
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01     -------------------------------------------------------
   Controller: 037 906 024 BE
   Component: DIGIFANT 3.2        1953
2 Faults Found:
00525 - Oxygen Sensor (G39)
            03-00 - No Signal
00513 - Engine Speed Sensor (G28)
            27-10 - Implausible Signal - Intermittent
Readiness: N/A
Address 03     -------------------------------------------------------
   Controller: 3A0 907 379  E
   Component: ABS/EDS ITTAE 20 GI V00
   Coding: 03704
   Shop #: WSC 00000
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
            16-00 - Signal Outside Specifications
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
            16-10 - Signal Outside Specifications - Intermittent
Skipping Address 15-Airbags
Address 25     -------------------------------------------------------
   Controller: 1H0 953 257  B
   Component: IMMO VWZ3Z0T2358765 V00
   Coding: 09600
   Shop #: WSC 00000
No fault code found.
End   -------------------------------------------------------
As you can tell there were a number of faults picked up on mine but i pretty much have them all sorted now!
Normally u wont get the full description of the fault code logged using the unregistered shareware version, but it will give you the fault code which u can just look up here anyway: http://wiki.ross-tech.com/index.php/Category:Fault_Codes (I managed to obtain a registered version of an older release 311.2 but it works great and shows u the full descriptions etc)
« Last Edit: 07 May 2008, 00:13 by flex »
Offline Ashley
Re: VAG COM
« Reply #11 on: 07 May 2008, 21:46 »
cheers for that flex. cant wait to get mine now!
it seems so easy for something that garages can charge a bomb for.. my mates 8v failed an mot because of a number of things and 1 of them was an "unknown electrical fault" which they were quoting hours on finding - if its as easy as plug it in and reference any codes with that site it'd be sweet as.
Offline Ashley
Re: VAG COM
« Reply #12 on: 08 May 2008, 14:32 »
OK - I've just ordered mine - just waiting delivery and we're away!
