Author Topic: New wheels and plates..  (Read 2156 times)
Offline Guy
Re: New wheels and plates..
« Reply #10 on: 05 May 2008, 10:32 »
Thanks mate....
Just gotta get the coloured caps that go over the screws and jobs a good un. Any ideas where from though..? Also need to find a way of fitting the centre caps as the wheel bearings push them off, might have to try spacers.
i used 3mm spacers on my mk4 rims... but you will still have to prise the hub covers off... lots of lovely grease underneath but you will be able to get the centre caps on but you might have to flatten the split pins a bit
i have done this on my mk4 rims but this isn't advisable and mine is only temporary as I am not happy with this arrangement
as for the nut covers... the stealers is an option... but the mk3 nut covers are taller/deeper than the mk4 ones which are a different shape so they will stick out a mile on the mk4 rims you have
i used my original nut covers and cut them down to size with a hack saw and then filed them down and then polished them
Offline shaft69
« Reply #11 on: 05 May 2008, 11:42 »
Need some number plate screw caps  :smiley:
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #12 on: 05 May 2008, 13:05 »
Got em ordered... :smiley:
Offline shaft69
« Reply #13 on: 05 May 2008, 13:15 »
Forgot to say nice plates, wheels look better on mk3 than mk4 i think anyways. seem some sprayed smoked grey on mk3 looked well nice.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline DazVR6
« Reply #14 on: 05 May 2008, 13:19 »
Thinking of eventually getting them powder coated in black and then painting calipers yellow, but gotta start a new job and get that outta the way before i do anything else.
Offline alexus1981
« Reply #15 on: 05 May 2008, 23:48 »
i was second in line for these wheels daz, you beat me to them you bugger!!! that guy still hasnt replied to my other pms yet, do you know if he's still selling stuff??
yOuR mUm...
Offline DazVR6
« Reply #16 on: 06 May 2008, 01:36 »
Well when i went to pick up the wheels he was still taking stuff off the car so not sure what he has left but he was still selling bits last i knew.
Offline eightyeightmph
« Reply #17 on: 06 May 2008, 08:26 »
Number plates I'm not a fan, but can see why you like them! :huh:
The grill isn't a GTI one. :afro:
The wheels look awesome, was going to get some before I got the BBS, 'new' nut covers fit the MK3 fine - I have them on mine! :wink:
2016 GOLF GTD
Offline boneybradley
  • Back in a Mk3...
« Reply #18 on: 06 May 2008, 13:38 »
I do like the number plates but the holes let them down :sad: ... thats why i have plate holders fitted as there screwed to the car and the holder clips the plates on!
and as said the grille is normal golf!!
