Author Topic: Cam lobe wear on GTI  (Read 10052 times)
Phil mcavity
Re: Cam lobe wear on GTI
« Reply #20 on: 06 May 2008, 07:11 »
so if this cam is on the camshaft, could it be that  the noisey tappet sounding engine that some peeps complain of, it this cam rattling around at low speeds??? its in that area and could make the same sound. Same as the old sounding CVH engines in the ford escorts with hydralic valve lifters that sounded tappity when worn or the engine oil needed changing.
Offline neg
« Reply #21 on: 06 May 2008, 08:21 »
I think the tapping people hear on this engine is just 'normal'
Offline neg
« Reply #22 on: 06 May 2008, 08:54 »
Copy of file as requested being as I saved it when it was available...
VW TSB on CAM Lobe Wear
Offline Cass
« Reply #23 on: 06 May 2008, 10:42 »
Thanks :smiley:
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline ukdub
  • WH05 DUB its my DUB
« Reply #24 on: 06 May 2008, 12:57 »
So what concerns would you expect if your have an AXX engine and looking at the HPFP upgrade - APR/Autotech
As I believe the AXX engine cam lobe to be fine, I would say that just faster cam follower wear. As will be the case with any make of HPFP due to the fact the pumps run with a higher than standard spring pressure.
This is a quote from APR's site
ROUTINE FUEL PUMP INSPECTION
On a periodic basis, around every ten thousand (10,000) miles, APR
recommends that you inspect the FSI fuel pump, cam follower, and camshaft in
accordance with the factory TSB for abnormal wear. If any wear appears to have
worn through the black wear coating on the cam follower, we recommend that
you replace the cam follower. Once this black coating is worn off, the wear rate
of the cam follower and lobe is dramatically increased. Keeping a good cam
follower in the car is critical to the long term operation of your vehicle.
The cam follower and camshaft wear rates on even stock vehicles appears to be
increased over what even VW/Audi has anticipated. We predict that VW/Audi will
either supersede these components to increase their longevity or they will begin
to include this inspection as a part of the routine maintenance of the vehicle.
We also highly recommend on any modified car an increased oil service interval.
Be sure to use oil that is VW 502 00 specification approved, and change the oil
on a regular basis, preferably every three to five thousand (3000-5000) miles.
I personally took my car off the Longlife service about 40k ago, and now change my oil every 7k using Mobile 1 0w-40.
Laser blue with BBS CH wheels in 19"
APR software, APR RSC turbo back exhaust, APR HPFP, Dbilas flowmaster intake, KW V3's
BSH speedshop PCV stage 2 fix but with Forge catch can
Phil mcavity
« Reply #25 on: 06 May 2008, 14:31 »
My engine is BYD, Is it just the bpy engines effected???
Offline 182_blue
« Reply #26 on: 06 May 2008, 14:36 »
how do you find your engine type
Offline 182_blue
« Reply #27 on: 06 May 2008, 14:45 »
ignore, just found it on the front of my service book, mine isnt a BPY either
Offline 08micsta
  • 1982 Mini 1275 Clubby
« Reply #28 on: 06 May 2008, 14:54 »
Hey there
Our Gti is a 2006 model from South Africa. Is this problem only an American/ Uk problem or should I be checking our engine type number thing too?
And I sound stupid but can someone please post up a pic of this number thing that is in the handbook. I called my mom to look and she cant find it....  :lipsrsealed:
Mike
The Ultimate Club for Mini Fanatics
Join our group now!
No PAS. No ESP. No DSC. No TCS. No ABS. Just my right foot between me and oblivion. Oh - And a seatbelt.
Offline 182_blue
« Reply #29 on: 06 May 2008, 15:13 »
its number 3 on the list in the front of your service book (should be a sticker)
