Author Topic: Quaife LSD  (Read 3609 times)
Offline RedRobin
Re: Quaife LSD
« Reply #10 on: 29 April 2008, 17:29 »
while there in the box it may be a good idea to swop the clutch over
....If I recall correctly, Quaife advised me that it wasn't at all necessary to change clutches on the DSG box. Also, on the DSG box of tricks at least, the ATB (LSD) is not at a deep level. :smiley:
Offline 182_blue
Re: Quaife LSD
« Reply #11 on: 29 April 2008, 17:48 »
was meaning more for manual users
Offline Hurdy
Re: Quaife LSD
« Reply #12 on: 29 April 2008, 19:29 »
I thought that £1400 was a little steep. The diff is just under £700 and so £700 for fitting seems a little on the heavy side.
Seat Leon Cupra Black 290 DSG
Offline RedRobin
Re: Quaife LSD
« Reply #13 on: 29 April 2008, 19:32 »
....If I do it, the guy I will use is Jim at JKM and he will want to keep the car for a day after just to make absolutely sure all is as it should be. He has fitted plenty of Quaife and Peloquin diffs but not to a Mk5 DSG Golf.
Offline Hurdy
Re: Quaife LSD
« Reply #14 on: 29 April 2008, 20:00 »
Yeah JBS are in the same situation. Lots of manual LSD's fitted, but no DSG versions.
Only guy I've heard of having one fitted is Ross Luffingham, who has an ED30 DSG with a Quaife diff. I'll have to see if I can get in contact with him to get some info.
Offline 182_blue
Re: Quaife LSD
« Reply #15 on: 29 April 2008, 20:01 »
what are the findings on the manual then ?, any good
Offline dubaiphil
Re: Quaife LSD
« Reply #16 on: 30 April 2008, 07:26 »
Anyone thought of getting one on here yet?
Just been quoted £1,433 inc vat and fitting for a ATB LSD for the DSG box, but I'm a bit hesitant.
Anyone had any other quotes and from whom?
Hurdy - Go for it!  A mate of mine in Dubai raced in the local Golf GTI series and he reckons the LSD had the biggest effect on his lap time - 2-3 seconds off on a 1:15 lap with the better traction.
Tornado Red 5 door, DSG, 18", Xenon, Cruise, Leather, Climatronic, Sunroof, RCD500, iPod prep, Mirror Package, Parking Sensors
Offline RedRobin
Re: Quaife LSD
« Reply #17 on: 30 April 2008, 13:28 »
....Only two other words excite Hurdy more than "better traction" and those are "carbon fibre"! :evil:
Offline Hurdy
Re: Quaife LSD
« Reply #18 on: 30 April 2008, 14:57 »
 :grin: :laugh:
Offline CHRIS-M07GTI
Re: Quaife LSD
« Reply #19 on: 01 May 2008, 01:11 »
I think £700 is a bit steep to fit also,is the diff not in a separate housing,i.e remove drive shafts,half moon casing and lsd will be no more wider bulkier than normal diff,nothing to do with gears or cluch packs!!! Dont get me wrong,big job,just emagine your diff goes,its not a total new gearbox,DSG or Manual,manufacturer's make them so they can be replaced indervidually,and a quaife lsd is more complex than standard,but built to the same size.
My Gsxr K51000 has a slipper clutch as standard,although you can buy a off the shelf slipper clutch for many bikes at a cost£300 i think,ie Gsxr k41000,but you dont have to buy a new gearbox/clutch.
Dont be ripped off hurdy,but get one!!!! :laugh:
Chris.
