had the same problem with my 8v. would drive fine the revs would die and pick up and then die, so on. and some times it would start up like it. turned out to be the maf sensor. if you can get the vehicle to do it at a stand still, open the bonnet and unplug the maf, if its the maf, when unplug the ecu puts a set vaule in and should run quick normal. hope this helps
andy
