Author Topic: coolant  (Read 1960 times)
Offline eightyeightmph
Re: coolant
« Reply #10 on: 26 April 2008, 19:51 »
G12 needs diluting 50/50 with water, thought the whole system was about 6 Ltrs?
Might be wrong with the last bit though, wouldn't mind a definate answer as I'm putting my new radiator on next weekend!
2016 GOLF GTD
kells
Re: coolant
« Reply #11 on: 27 April 2008, 13:26 »
6.3 litres  :wink:
Re: coolant
« Reply #12 on: 27 April 2008, 13:34 »
Thought it was around 6lts!
Thanks Kells! :wink:
2016 GOLF GTD
Offline gtiscott
Re: coolant
« Reply #13 on: 27 April 2008, 13:50 »
cheers guys
Offline golfmk31993
Re: coolant
« Reply #14 on: 27 April 2008, 14:05 »
ive just bought a bottle of coolant from tesco, its tesco's own summer coolant, i have just been topping up my exspansion bottle with water in the past and i thought that this tesco's coolant must be better than water,
is it ok to just top it up with the tesco's coolant or should i drain all the old water out?
is it ok to use water ? im not sure wot was in the car when i bought it, but ever since ive just used water
Offline nelds
  • Now Golfless but owning an Audi still counts
Re: coolant
« Reply #15 on: 27 April 2008, 14:20 »
i'd flush the system and use the pink halfords stuff, it's pretty much the same as G12. that way it'll get rid of the old stuff plus the tesco mix
Offline gtiscott
Re: coolant
« Reply #16 on: 27 April 2008, 14:48 »
what do you do to flush the system?
Offline Pete Taylor
Re: coolant
« Reply #17 on: 27 April 2008, 17:22 »
buy some rad flush. They all have different instructions so i couldnt tell you how do do it. Go for the powder stuff  you can put in the expansion bottle rather than the gritty stuff that you can only put into the rad
