Author Topic: V.Lumpy Idle  (Read 1104 times)
Offline ollie6n
  • Spartan Lowrider!
V.Lumpy Idle
« on: 24 April 2008, 15:07 »
Hey guys, I've just been out for a spin in my car to get some photos only after parking, started it up and it sounds like its misfiring now. . . v.strange as it wasnt before, it's dropping to about 750rpm and almost stalling, then it will jump up to around 1500rpm. . . I've just taken all the HT leads off to see if I could find a problem there but no such luck, havin a pretty sh!tty day so far so any help would be well appreciated!
Offline ollie6n
  • Spartan Lowrider!
Re: V.Lumpy Idle
« Reply #1 on: 24 April 2008, 18:04 »
Any Ideas spring to mind anyone, was hoping someone may have had the same problem. . .
Offline boneybradley
  • Back in a Mk3...
Re: V.Lumpy Idle
« Reply #2 on: 24 April 2008, 18:08 »
possible vacuum leak as thats causes similar issues..check all the breather pipes are ok
i think stopping it and restarting it is just coincidence?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: V.Lumpy Idle
« Reply #3 on: 24 April 2008, 23:16 »
Clean the throttle body?   seems to be the answer to most problems on golfs  :grin:
Mabey its the idle up valve?  the Idle stablisation valve as its called on a golf.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
  • Back in a Mk3...
Re: V.Lumpy Idle
« Reply #4 on: 24 April 2008, 23:19 »
only on the bosch injection (early 8v and all 16v) tho.... the simos 8v dosen't have one!!
Offline Rmachines
Re: V.Lumpy Idle
« Reply #5 on: 24 April 2008, 23:28 »
Ok in that case it will be one of the following.....
ECU - Basic setting/coding
Air intake system/vacuume leaks
Fuel pressure /regualtor
Condition of fuel/filter
Idle air control (IAC Valve)
Idle speed control actuator
Idle Actuator possition sensor
Evaporative emssion cansiter perge valve
Injectors
Engine coolent temp sendor
O2 Sensor
MAF Sensor/MAP Sensor
Air intake temp sender
Engine Compression
Engine managment connections/wiring
Engine control module.
Now.. where do you start  :grin:
Offline ollie6n
  • Spartan Lowrider!
Re: V.Lumpy Idle
« Reply #6 on: 27 April 2008, 19:22 »
~Haha, problem solved! There's a vacuum hose leading from the top of the inlet manifol all the way back to the ECU. . . cotton overbraid it is, the hose had split and come off, stuck another bit in its place, all sorted, got some more ordered though, re-do all the overbraided vacuum hose I can find now :laugh:
