Author Topic: GTI ignition leads... where from?  (Read 1561 times)
Offline cняis
Re: GTI ignition leads... where from?
« Reply #10 on: 24 April 2008, 14:44 »
3 sets in 18 months, that cant be good  :undecided:
plugs that is.
the first set were really bad went i got the car, probably just old. plus two spark plug holes were leaking (!) so i thought "new plugs and washers"
second set i fitted myself, no problem (im not retarded).
then the car started pinking, was probably doing it before but summer was setting in, perhaps it was just worse with the higher ambient temperature?
third set were fitted whilst the engine was being tuned, 3 electrode thingies. garage commented on the state of the second set, as timing was out and it was underfuelling.
fourth set fitted during a service a month ago and the guy said that the triple electrode plugs couldnt be cleaned adequately, so another new set...  :rolleyes:
two spark plug holes still leak very slightly.
Offline markymark
« Reply #11 on: 24 April 2008, 14:48 »
I put a set of Magnecor leads on my 16v and it has been sweet. They aint cheap thou, I got mine sent from Awesome Gti
Offline cняis
« Reply #12 on: 24 April 2008, 14:56 »
might go for their 8mm leads, thanks  :smiley:
