Author Topic: Oh God, what do I do?  (Read 2169 times)
Offline Len
Re: Oh God, what do I do?
« Reply #10 on: 25 April 2008, 08:57 »
So Simone what have you decided?
www.sas.org.uk
www.the-ace.org.uk
Offline SBMIII
« Reply #11 on: 25 April 2008, 17:47 »
I'm still undecided! The garage has just quoted me £580 to work plus I'll supply the cylinder head (£105)  :sick:  I'm just worried that I'll fix this and then something else will go (reverse is a bit crunchy).  I think I'm going to try and sell it off bit by bit and borrow a large wadge of cash to buy something half decent.
Thanks for all the answers,
golf-less Sarah :cry:
Offline boneybradley
  • Back in a Mk3...
« Reply #12 on: 25 April 2008, 18:08 »
i wouldn't repair it.... break the car and then buy one that works!! I had this with my first gti.... the gearbox let go and i paid silly money to get that sorted, then the suspension broke and i got that done and then it failed the m.o.t on emmisions and I gave in and decided to buy another...lucky really as when i broke it loads of dodgy/bodged up bits became aparant!!
or if your adamant and really want to keep it try robiwill on here (check the parts area) and see how much he wants for a full top end or engine...
Offline harlemex
« Reply #13 on: 26 April 2008, 22:43 »
Is the cylinder head complete? ie. does it have its valves, camshaft and rockers etc. in place? If so, where did u get it? Do you know if it is in good condition? If yes to the above, fitting it is not so bad and should be a lot cheaper than what you,ve been quoted. You will need a head gasket,head bolts, inlet and exhaust manifold gaskets and antifreeze. Get your parts from gsf or europarts in poole(or bournemouth if they have places there) What year is your car? I could fix it for you if the head parts mentioned are intact. :smiley:
Offline bored_Welsh_lad
« Reply #14 on: 27 April 2008, 09:58 »
If it was me.. id drop in Rmachines 2.0 8v lol... thats what id be looking at anyways... you say your shell is mint...so keep the shell and drop a diff lump in it...
Mk3 Golf Gti:Full Milltek system and Decat,K&N filter,mk2 Cam,-1.5 degree camber shims, borbet a's, toyo proxies,hot tuning coils, brembo vented discs, greenstuff pads...Soon to have Eaton Power
mk3 16v 5dr Gti,mintex extreme pads,drilled/grooved discs,lowered,cat back powerflow system,omp panel filter with modified airbox,debadged grill, started prep for spraying, lots to come :D
Bumper Vents :D
