Author Topic: Which fan upgrade?  (Read 2025 times)
Offline Thom89
  • Looking for an "Icebreaker"
Re: Which fan upgrade?
« Reply #10 on: 23 April 2008, 23:22 »
ok lads calm down :wink:
Thanks for all your suggestions, i have already made up an overide switch for the fan, What i failed to mention also is that im considering planting a 1.8t in her, This is an engine demanding a lot more cooling than that of a standard 1.8 8v being a turbo'd engine etc... I have considered oil cooling also and will decide the best oil cooler for her when the 1.8t is planted. I read on one thread a member had fitted a mk3 diesel fan? Does this require much modification and does it require extra work in terms of mounting?
Thanks again guys jus remember were all on the same team here  :wink:
Unless i see you on the track  :grin:
Dirty, we use these fans on all of our race cars http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=ROAD&pcode=PCTCF22 dead easy to fit, and will give you plenty of extra space...
Tom
Offline Khare
  • The bear that khares
« Reply #11 on: 23 April 2008, 23:25 »
formula 1 dont have fans.
Lol, that's the first time I've ever heard of a MK2 Golf being compared with a F1!
well you have never studied mk2's in detail then :laugh:
Offline Thom89
« Reply #12 on: 23 April 2008, 23:36 »
VW Golf GTI F1..... :smug:
Tom
Offline mk2mark
« Reply #13 on: 23 April 2008, 23:44 »
Ok simply put, if your cooling isn't up to track days it's got nothing to do with your fan, you need a better rad.
I can't put it any simpler than that.
Offline Dolly
« Reply #14 on: 24 April 2008, 10:26 »
i  know you can get thermostats that open earlier and fan switches that get the fan in a little earlier from neuspeed if you havent done this already worth a thought.
VeeDubGTI16v
« Reply #15 on: 24 April 2008, 17:42 »
Tom
does the thermostat for those fit in the rad in place of the original? think its M22 but i have no idea what the golf size is!
« Last Edit: 24 April 2008, 17:59 by veedubgti16v »
Offline Diamond Hell
  • Opinions я Us
« Reply #16 on: 24 April 2008, 18:50 »
Go find a Toledo 2.0 8V - I have a set of fans off one on my radiator in my Syncro.  Instead of the rubber flaps etc it allows airflow through the whole radiator.  Mine's mounted up on a radiator from an ABF G3, which took a little work.
Next up is an oil cooler, as the Golf1 GTI doesn't fit on a 2.0 block, annoyingly.
Offline Uruk Hai
« Reply #17 on: 26 April 2008, 09:15 »
The only other thing I would do is have a fan by-pass switch that allows you to switch it on as soon as your coming off the track instead of waiting for the fan to cut in by itself.
