Author Topic: trackday prep - what you have done and what do you recommend?  (Read 261298 times)
Offline Diamond Hell
  • Opinions я Us
do the 'flip'  :wink:
This needs elaboration.
Offline Organisys
  • Old and Slow...
...just means flip the wishbones back down flat again. Bushes suffer, not to mention more pressure on the ARB too....
  • Opinions я Us
Nope, still don't understand.
Offline Simeon
Re: trackday prep - what you have done and what do you recommend?
« Reply #53 on: 30 August 2012, 13:40 »
He probably means flip the track rod ends to try and sort the geometry out like the aircooled guys do.
Offline mk2 helper
« Reply #54 on: 30 August 2012, 14:12 »
how can this be done though as track rod ends are a tapered fit ????
if in doubt go flat out
Offline Simeon
« Reply #55 on: 31 August 2012, 13:23 »
You drill out the hole and fit a new insert which is tapered the other way.
Offline lemski
  • 16v
« Reply #56 on: 01 September 2012, 10:00 »
how would that work. Wishbones would still be off if u flipped trackrod ends
Offline Simeon
« Reply #57 on: 03 September 2012, 00:54 »
I wasn't talking about wishbones. Flipping the trackrods sorts the bump steer out that you get when you excessively lower your car.
Offline mk2 helper
« Reply #58 on: 03 September 2012, 11:56 »
then a rose jointed set up would be suited better as you can space these out to get an accurate set up. been searching this and for around 80 quid you can buy longer rose jointed track rod ends wich are supplied with spacers to achive the desired effect.
« Last Edit: 03 September 2012, 13:30 by mk2 helper »
Irving0
« Reply #59 on: 09 September 2012, 01:44 »
i havent done any trackdays yet but im almost ready and will deffo be doing them this summer.
