Author Topic: Camber and Tracking question  (Read 4238 times)
Offline richy
  • neeeeeeeowm
Re:Camber and Tracking question
« Reply #10 on: 20 April 2004, 21:51 »
Already have - doesn't seem to mention ANYTHING about adjusting camber.  By this I assume it means you can't!  ;D
54-plate Golf 2.0 FSI GT.  Leather interior.
Offline richy
  • neeeeeeeowm
« Reply #11 on: 20 April 2004, 22:17 »
Hang on... Just found the following in me Haynes manual:
"Checking and adjusting the front wheel camber angle should be entrusted to a VW dealer or suitably equipped specialist. [...] Adjustments are made by loosening the front suspension subframe mounting bolts and repositioning the subframe".
It says rear camber and toe-setting is not adjustable.
It also quotes the following settings:
Front camber angle
(sports suspension) -33' +/- 30'.
(standard suspension) -30' +/- 30'
Toe-Setting
(sports suspension) 0 degrees +/- 10'
These must be the settings that the VAG specialist that I went to used when they checked my camber and tracking.  (They said that they had checked them and that they needed no adjustment).  I reckon it'll be OK - I'll just leave it.
Thanks for all your help.
Richy.
« Last Edit: 20 April 2004, 22:52 by richy »
golfvr6
« Reply #12 on: 20 April 2004, 22:41 »
Nice one, should be ok anyway as you have re-used the original front struts.
Car looks alwight  :D
Offline richy
  • neeeeeeeowm
« Reply #13 on: 20 April 2004, 22:52 »
Cheers, mate! 8)
