Author Topic: Interior lights - HELP  (Read 2090 times)
Offline VW_08
Re: Interior lights - HELP
« Reply #10 on: 23 April 2008, 17:22 »
one or two of my heater dials arent lit either  :laugh:
So how do you take the front panel off to get to the bulbs? is there a screw(s) somewhere? pics?
Offline MowatGTI
« Reply #11 on: 23 April 2008, 23:28 »
Yeah - i'd like to know too.
Can't remeber if Haynes book tells how or not.
I'll have a look tomorrow
kells
« Reply #12 on: 23 April 2008, 23:37 »
panel round the dials just clips off, use thin screwdriver.
theirs then a few screws which hold the surround in place, remove all these, think u will have to remove ashtray and theirs screws near that area too, the whole surroubd comes off 9dead easy to do)
then theirs 4 screws holding the heater controls in place, remove them and just tilt the unit forwards so u can get acces to the bulb holder
only 1 bulb as standard on all mk 3 models
dials vairy dependant on year, older ones has lots of bulbs, most for the warning lights etc like handbrake etc etc, lates ones use chip leds and only have a couple of user replaceable bulbs, these are for the indicator arrows and the 2 that light the face of the dials up, all years only have 2 that illuminate the dial faces, 10 min job at the most to change
hope this helps /makes sense
Offline ineson
« Reply #13 on: 24 April 2008, 13:25 »
Great thanks kells, she has been going on at me to get this done so will sort it tonight for her.
kells
« Reply #14 on: 24 April 2008, 13:41 »
no problem matey
the heater dials dont light up very good in standard form anyhow just beware of that. the clocks are easy to do, you need to remove the headlight switch, do this by removing the panel to the right of it with a screwdriver, theirs a tab on the inner right side of the headlight switch, press this in and the whole switch will slide out, might be a bit stiff, leave the connector conected to it. theirs screws to remove the dials surround, take the scres out. theirs another screw to the left side of the dials too behind another plastic panel (to the right of the stereo) remove this with a screwdriver (just prize it off)
when u have removed the screws, the surround which goes around the dials will pull off, again this could be stiff as theirs some tabs on the top.
theirs then 2 screw that hold the clocks in palce. undo these and the dials will drop forward, undo the connector on the rear and take them out from car, the 2 bulbs are ont he top you will see them
Offline MowatGTI
« Reply #15 on: 28 April 2008, 14:05 »
Sorry to drag this topic up again, but I've just had a go of looking to see where the bulb holder for the heater dials is.
I have taken some pictures but I forgot to pack my phone-laptop cable, so will have to wait untill Wednesday to upload these.
So far, taken out ashtray and the heater dial cover.  Unscrewed the 6 screws that hold it all together.
This loosened the lower part which I could loosed and move out the way.
I also could take the dial part out, but only about and inch or so because the cables were holding it in.
I had a wee feel around for a bulb but couldn't see anything.
Anyone direct me to it??
Offline sharki786
  • GOT BOOST??
« Reply #16 on: 14 July 2009, 19:12 »
hi all, which bulbs do i need for a 1996 p reg anniversary speed clocks? kells did a write up on his but doesnt state what type of bulbs he has used or how he has used the uv and blue? need help as im diying to do that speedo mod which blue or red lights, anyone seen the red light conv??? would be greatful if someone helpd me out i been looking on this forum since yesterday.  :cry: need to know the resistors and what type of smd led to use? just need a bit a guidance! im a complete novice to this.
Thank you all!!!
*****MK3 Anniversary*****
*****MK4 GTI T*****
