Author Topic: MK2 GTI No heaters and NO Wipers and only 38k on the clock - warranty ?  (Read 1668 times)
Offline Mr Blue
you lot will be at work tomorrow while ill be on my way.
Now you learn!  :cool:
Offline rombonie
Arh but when you work for yourself.... :wink:
check the x-over relay, grey one with 18 on the front.  This should click as soon as key is turned, if not its kaput or the ign switch isn't passing current to it somewhere along the line.  Double check the relay positiuons as per my fusebox FAQ as well, in case someone took it out and put it in the wrong place!
Offline mk1inbits
Thanks for the tips, will try and look at the weekend , just to clarify bith wipers and heaters work but only intermittently, and since the weather got warmer they work even less frequently.
JUst want to start using the car and getting the engine freed up
