Author Topic: just back from awesome and my car is AWESOME!!  (Read 2596 times)
Offline gazbutmk5gti
Re: just back from awesome and my car is AWESOME!!
« Reply #10 on: 16 April 2008, 17:16 »
That's a different type of DV valve as used on the 1.8T and such like that yout talking about, the Tfsi engine uses an solenoid controlled valve which also forms part of the traction control system. The forge replacement DV for the Tfsi is preventive mod to replace the standard item which is known to give problems when running higher boost, although it seems mainly the regular GTi that its a problem on. This could be down to its hot location bolted directly to the turbo
Revo stg2+ & lots more
Offline joesgti
« Reply #11 on: 17 April 2008, 11:58 »
yea looks like this
GTI MK5
Not the only GTI...........but the best! ; )
Offline LaserBlue
« Reply #12 on: 17 April 2008, 18:33 »
so do you guys recomment not changing it?>
im getting my car apr stage 1 next month and wondered if i would have to change anything else?
ive been told to also fit a full exhaust and air intake to get the best results outta the remap?
also i have not got cruise control so will i not be able to switch it on and off as stated on awesomegti>?
hope its worth the £650
Offline neg
« Reply #13 on: 17 April 2008, 19:11 »
If you can afford it I would change it for piece of mind, I have had one on mine since they were released and I have had no problems at all.
A exhaust system will just help it Rev better, if your going for a full system and filter you may as well get Stage 2 software surely to make the most of it...
Which remap are you referring to - just APR?
Offline LaserBlue
« Reply #14 on: 17 April 2008, 19:21 »
yes im goin for the apr..
ive ben looking into remaps for ages and decided apr was the best.. they even work with vw tuners so they gotta be good.
i think its an extra 50-65 bhp?
can just about afford that and the cruie control unit total £650 without fitting  :sad:
guess the intake and exhaust can wait a little longer
hey also i didnt know the gtis are not 200 but 195bhp so stated in the dyno results seen.
Offline neg
« Reply #15 on: 17 April 2008, 19:38 »
Dyno results are only an indication - hence the term "dyno lottery", also every car is different.
For a stage 1 remap realistically I would say expect 240-245.  Dont worry about figures, drive it and you will tell the difference and it will give you more smiles per mile  :grin:
