Author Topic: RCD Removal tool, trim tools required!  (Read 3810 times)
NewGolf
Re: RCD Removal tool, trim tools required!
« Reply #11 on: 12 April 2008, 10:19 »
I think they are for the older type, I just had a look and cant see any slots. I think p3eps is right and I only need a trim tool and 1 torx screwdriver.
I like the sound of an apple tool though, sounds useful! You have to have all the tools to do a good job, its heartbreaking to damage your trim on a new car and have to look at it everyday... :sick:
Appreciate the help guys.
Offline 182_blue
« Reply #13 on: 12 April 2008, 10:36 »
thought so, but i have 500 so not sure
Offline Merlinman
  • Tornado Red 170ps GT Sport
« Reply #14 on: 12 April 2008, 11:40 »
Try here  :wink:
Scroll down - its all there !
NewGolf
« Reply #15 on: 12 April 2008, 14:04 »
Try here  :wink:
Merlinman you are a star! Thats just what I needed. Thumbs up to you  :smug:
Offline 182_blue
« Reply #16 on: 12 April 2008, 14:15 »
good luck, i had a quick test run on mine a moment ago and first bit was ok, but the other panel seems like its going to break when you pull at it !!!
NewGolf
« Reply #17 on: 12 April 2008, 14:20 »
Yikes! let me know how you get on, with any hints/tips!
I read that you should let the car get warm to make the plastic less likely to snap....
Offline Bolle
« Reply #18 on: 12 April 2008, 14:26 »
I've removed the nav/radio about 4 times, nothing snapped on my sofar. Only thing that came loose were the small metal clips attaching the fascia surround, these can easiliy be glued back on. I would advise care when putting the center exhaust piece back in, there are a few small tabs which have to be inserted right or it will not fit, and using force at that point will snap these tabs.
If it's cold outside, i do drive around for a few minuts with heater on hi and all the air exhausting trough the center vents to get the plastic more flexible.
Just don't be afraid to use a bit of force...
Offline 182_blue
« Reply #19 on: 12 April 2008, 14:28 »
The heat thing makes sense  :smiley: , will try that when the time comes
