Author Topic: door lock  (Read 982 times)
Offline E4NER
door lock
« on: 09 April 2008, 18:03 »
when i push the button on drivers door to lock all doors passenger door lock pops back up? how do i fix how much is the part and is it easy
Offline uber pikey
Re: door lock
« Reply #1 on: 09 May 2008, 12:04 »
You need to see if the button is screwed down to far as it jams and the motor pushes it back up, if this doesn't work then remove the door card and check the adjustment on the motor housing. Also check the motor operation when disconnected as this will push you in the direction of the fault.
I saw it so I took it.
