Author Topic: Bonnet Vent - Placebo Effect or Reality?....  (Read 5519 times)
Offline topher
  • Administrator
  • fully functioning
Re: Bonnet Vent - Placebo Effect or Reality?....
« Reply #10 on: 08 April 2008, 15:33 »
<insert long boring rabble about syphonic effects and drag>
it will improve airflow, but to what extent i wouldn't even want to guess... i think you can get temp readings from vagcom though, could be interesting to compare a standard gti against robins.
Offline Hurdy
« Reply #11 on: 08 April 2008, 15:33 »
The only true way to find out would be to rolling road test it. It may have a minimal effect, but the bonnet on a car is hardly airtight anyway. It does make sense to have the vent letting out hot air rather than taking in cool air as most of the cooling is done by the intercooler, but the heat that is generated could be pulled away faster by a vent.
RR does your car still run at 90 degrees when warmed up? - I suspect it will and therefore the benefit is negligible.
Looks mint though :cool:
Seat Leon Cupra Black 290 DSG
Offline Ridg
  • TDI - Soot Happens!
« Reply #12 on: 08 April 2008, 15:47 »
vagcoms only going to give you the coolant temp isn't it (not sure what sensors you've got in the MK5)? at which point the thermostats going to be keeping the engine at 90, so could mean the radiator doesn't have to do as much work if the cooling improved?
Offline neg
« Reply #13 on: 08 April 2008, 16:25 »
When in motion surely the vent will be sucking cold air in ?
Dont quote me but I remember reading something about bonnet vents and majority of people thinking they would help release the hot air when in fact when moving the draw the air in - like when you open a sunroof on tilt you feel a draft coming in not out ...
I could be talking bollox though  :huh:
Offline Hurdy
« Reply #14 on: 08 April 2008, 16:30 »
Look at his vent  in the full bonnet pic Neg, it's facing the other way to draw air out  :wink:
Offline joesgti
« Reply #15 on: 08 April 2008, 16:51 »
it will not make any difference what so ever, that you can possibly feel!!
looks AMAZING thow and i want one, couldnt afford one at the moment thow :sad:
GTI MK5
Not the only GTI...........but the best! ; )
Offline RedRobin
« Reply #16 on: 08 April 2008, 17:52 »
....Good point about the temp gauge at 90, Hurdy - I'll check it out.
It seems that IF there is any benefit, it's only subtle or very slight although the whole engine bay has felt cooler when I've opened the bonnet after a run. Yes, even though I say it myself, it does visually look cool :cool:. Nothing wrong with some nice eye-candy :evil:.
Offline Hurdy
« Reply #17 on: 08 April 2008, 18:14 »
Wait till you see my all new eye candy on Sunday :evil: :wink:
Offline RedRobin
« Reply #18 on: 08 April 2008, 18:22 »
....Methinks we should try and park next to each of on our stand - A carbonfibre fest!! :evil:
[I'm visiting the TTshop tomorrow]
Offline Hurdy
« Reply #19 on: 08 April 2008, 18:41 »
OHHHHHHHHHHHHHHHH my new bit is much sexier than carbon fibre :rolleyes:
and you'll have to wait and see on the day :wink:
