Author Topic: Screen wash  (Read 8215 times)
Offline 182_blue
Re: Screen wash
« Reply #10 on: 17 May 2008, 16:52 »
would it really void your warranty if you use non VW screenwash ?  :huh:
NewGolf
Re: Screen wash
« Reply #11 on: 17 May 2008, 20:40 »
No Chance!
Offline 182_blue
Re: Screen wash
« Reply #12 on: 17 May 2008, 21:05 »
Offline vRStu
Re: Screen wash
« Reply #13 on: 17 May 2008, 21:20 »
It will not void your warranty in it's entirety however they may refuse to carry out repairs on the system should there be a problem.
This TSB is issued by Skoda following a common problem with pipes blowing off, it clearly states that use of non VAG additive will mean it becomes a chargable job -
http://www.fabia-vrs.com/technical/washer_pipe.htm
Stu
Offline Teutonic_Tamer
Re: Screen wash
« Reply #14 on: 06 September 2008, 12:19 »
Genuine VAG screenwash is also available from GSF, should anybody find them closer than a stealer.
BTW, the screenwash concentrate from Lidl is also OK, as it contains water softeners, which prevent the limescale forming on the jets.  It's made by a German company, VCP, I think, and has the identical temperature rating as the VAG stuff - down to minus 70C when used neat (what you chaps with open fog grilles will need to use in the winter!  :tongue::laugh:
I feel like a homo
Offline mrlapou
  • Mean GTi
Re: Screen wash
« Reply #15 on: 20 September 2008, 16:02 »
I have used bought Halfords, VAG plus other screen wash additives. Have found, mixing different makes of screen wash leads to a smeared windscreen.
My advice is, wash out the old water from the bottle before using a different brand of screen wash.   :smiley:
Offline jphealy
Re: Screen wash
« Reply #16 on: 11 February 2009, 14:33 »
How do you wash out the bottle?  Is it removable?
Offline topher
  • Administrator
  • fully functioning
Re: Screen wash
« Reply #17 on: 11 February 2009, 15:27 »
Just put clean water in and hold the p!ssers down until empty. Rinse and repeat.
Offline pazz
Re: Screen wash
« Reply #18 on: 11 February 2009, 23:00 »
Does the warning light for the washer fluid come on pretty early? Mine started telling me it needed refilling about 2 weeks ago now and its still going.
I'm wanting to wait till its pretty much bone dry to then wash it out as above.
Re: Screen wash
« Reply #19 on: 19 February 2009, 11:22 »
It depends on weather you have headlamp washers.  The warning (if fitted, because it is only fitted with the optional 'Winter Pack'  :wink:) usually comes on when the bottle is about three quarters empty.  What then happens - it sort of goes into a 'washer fluid preservation mode'.  The headlamp washers will first stop working, then the rear screen p!sser, and the front screen washers will only stop when the bottle is completely empty.
It all depends on what washer fluid you have used - because as Mr Lapou correctly pointed out, mixing certain different kinds of washer fluid can actually cause it to form 'jelly' like substances in the bottle, and will seriously clog fan jets, especially if they are heated.  The cheaper, poor quality washer fluids tend to be made of methanol - which is just the proper name for the primary agent in methylated spirits (meths).  Whereas the better quality fluids (including the genuine VAG, and the VCP stuff from Lidl) use the higher quality ethanol, which is pure alcohol <hic, hic, hic :evil: >.  And just like engine oils, washer fluids also have 'additives' in them too.
So, if you are damned not to use the genuine VW stuff all the time, try at least to use one which is ethanol based, rather than methanol.  Good luck in finding some though, because the vast majority of screen wash fluids are still based on methanol.  A good tip is to check the frost protection - the genuine VAG and Lidl fluids go down to minus 70degC - whereas the methanol ones only go down to minus 20, minus 30 if you are lucky.
HTH
I feel like a homo
