Author Topic: Rear VW Sharan Badge mod.  (Read 79292 times)
Offline richw911
« on: 05 April 2008, 17:59 »
Today ive almost finished colour codeing my new smaller rear VW badge.
If you old rear badge is anything like mine its gone gray and the rubber on the edge has started peeling from age.
The new one is from the vw sharan and is smaller than the standard mk4 badge (Badge measures 90mm in diameter) -and will sit nicely inside the indent on the tailgate - Nice subtle mod :afro:  :wink:
I know lots of you have done this already its one of these mods ive been meaning to do for ages  :evil:
When finished should look like this:
To Remove your huge VW frisbee  :grin: :
You will need:
1.Sharan Badge- part no 7M3853630AULM  approx £20 or so now  :sad:
2.Double sided foam /tape
3.Wet and Dry Paper 600/1200
4.Spray paint - Got mine from halfords mixed from paint code :afro:, Lacquer
5.Plastic Primer
6.Stanley knife
Have a look at this and see what you think  :smiley:
First thing you need is the rear badge from the vw sharan part no: 7M3853630AULM
Heres a pic of the new and old one together:
Now you need to remove the sticky tape from the badge:
Next you need to remove the glue from the six lugs at the back of the badge i used a stanley knife.
Now it should come apart  and look like this:
Now use some 600 grit to "key" up the backing of the badge:
Then prime with plastic primer, Tip; put the spray can in a tub of hot water to get the paint nice and thin and up to room temp. :wink: :
When the primer is completely dry again "key" it up but this time using 1200 grit paper.
Next apply the first coat of your body colour - Take your time and never rush when painting alway wait for the paint to dry completly before next coat:
I gave mine three coats -  "keying" Each time using 1200 wet and dry paper between coats.
Next when colour paint is completly dry its time for the lacquer- Again you need to use 1200 grit and plenty of water to lose the shiny top coat.
Now this may seem strange to sand the top coat but you need to do this to achieve the correct colour match and for the lacquer to "take" properly.
After its completely dry you need to place it back together and re - glue the six lugs where you removed the original glue.
More pics to follow when my lacquer is dry and it is fitted to the car  :laugh:
« Last Edit: 19 December 2011, 21:46 by richw911 »
Offline GTi-Matt
Re: Rear VW Badge mod.
« Reply #1 on: 05 April 2008, 18:47 »
proper job ur doing there ricky,cant wait to see it on the car :afro:
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline richw911
« Reply #2 on: 05 April 2008, 18:49 »
Thanks mat - if you need any help with yours just give me a shout bud  :wink:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #3 on: 05 April 2008, 21:02 »
lookin good rich how long did it take u?
wat was the old 1 like to get off ?
nice cool subtle mod ill be doin mine soon
Offline richw911
« Reply #4 on: 05 April 2008, 21:07 »
Thanks mate, its taken most of last week - but thats because i was working late some days and allowing 24hr to dry between coats; Golden rule NEVER rush when working with paint!  :smiley:
I havent taken my old badge off yet mate so i shall let you know,
Tho is only stuck on so shouldnt be too much of a prob to get off TBH
« Last Edit: 05 April 2008, 21:36 by richw911 »
Offline leeroy20vt
  • h reg mk2 gti
« Reply #5 on: 05 April 2008, 21:11 »
Thanks mate, its taken most of last week - but thats because i was working late some days and allowing 24hr to dry between coats Golden rule NEVER rush when working with paint!  :smiley:
yer know what ur sayin bout rushin lol get some pics up as ur takin it off m8 i seen 1 before and it was pretty messy behind
good luck fella
Offline richw911
« Reply #6 on: 05 April 2008, 21:13 »
good luck fella
Ok bud will do cheers  :wink:
Offline Rhyso
« Reply #7 on: 05 April 2008, 21:46 »
looking good rich
look forward to getting mine :afro:  :wink: :grin:
Offline S7CYW
  • DUB
« Reply #8 on: 05 April 2008, 21:50 »
good luck fella
They're pretty easy to get off, prizing the bade off with a bit of heat/hot water to soften the sticky foam pads helps. Stickiness left over can be rubbed off, polished up to clean throughly.
Mines off currently as have been painting it black, but might opt for the sharan badge shorty  :smug: looks ace!
Offline richw911
« Reply #9 on: 05 April 2008, 21:52 »
looking good rich
Cheers rhys :afro: If you like yours will be next  :wink:
« Last Edit: 05 April 2008, 21:56 by richw911 »
