Author Topic: torque arm  (Read 4147 times)
Offline k4ith
Re: torque arm
« Reply #10 on: 06 April 2008, 13:14 »
is this an easy diy?
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline Hurdy
Re: torque arm
« Reply #11 on: 06 April 2008, 13:49 »
If you can get under the car and get leverage I'm told it is a ten minute job :cool:
Seat Leon Cupra Black 290 DSG
Offline SteveS
  • GTI ED30
Re: torque arm
« Reply #12 on: 06 April 2008, 14:32 »
do i HAVE to use a torque wrench
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline RedRobin
Re: torque arm
« Reply #13 on: 06 April 2008, 15:03 »
....It's ALWAYS a good practice to use a torque wrench so that you tighten something to the recommended tension - It protects you from being not too tight and not too loose for the application.
Offline Rhyso
Re: torque arm
« Reply #14 on: 06 April 2008, 15:14 »
get this :afro:
http://www.screwfix.com/prods/18289/Hand-Tools/Spanners-Wrenches/Wrenches/Torque-Wrench?cm_re=SEARCHPROMO-_-TORQUE%20WRENCH-_-18289
well useful for bits and bobs; mainly use it for torquing my wheel bolts correctly  :smiley:
Offline SteveS
  • GTI ED30
Re: torque arm
« Reply #15 on: 06 April 2008, 15:27 »
anyone know where i put the axle stands on the car? same point at the normal jack?
SteveS
Offline SteveS
  • GTI ED30
Re: torque arm
« Reply #16 on: 06 April 2008, 17:21 »
well doesnt look like ill be doing it today, aint got no bloody torque wrench! grr
SteveS
Phil mcavity
Re: torque arm
« Reply #17 on: 07 April 2008, 08:07 »
torque wrench normal means just do it up tight!!. How tight is it asking you to tighten it??? how many lb's ft is it ment to be tight steve??
Offline vRStu
Re: torque arm
« Reply #18 on: 07 April 2008, 08:36 »
Steve
Look under the front of the car to the rear of the engine and you'll see the Aluminium bush holders they are curved and fit perfectly into axle stands.
If you put them where you jack up on the sill you'll probably do some damage.
This is a Fabia but you'll get the idea - http://www.fabia-vrs.com/images/images/eibach/eibach43.jpg
Stu
Offline SteveS
  • GTI ED30
Re: torque arm
« Reply #19 on: 07 April 2008, 09:10 »
it was 74lbs
i managed to get it done nexy door neighbour had what i needed!
not had time to test, but when i do. ill let u know
SteveS
