Author Topic: Fitted the R32 Intake today!  (Read 9197 times)
Offline Lee_dub
Re: Fitted the R32 Intake today!
« Reply #21 on: 04 April 2008, 11:53 »
Thats the badger! Its quite a handy tool to have.  you will need it to bore a bigger hole in the side of your airbox, and you might as well smooth the inside whilst your there! oh and underneath your filter there is a sort of funneling pipe that you need to remove, it sits on a clip.  Rip it out and then smooth of the bracket.
Sounds like its got alot more balls now
Black mk1 2.0 16V - woop
Offline the_stink
  • A3 140 TDI
« Reply #22 on: 04 April 2008, 13:42 »
sounds like an episode of blue peter  :grin: right kids all your going need is a drill, a friend, a fairy liquid bottle and some sticky back plastic, lol
Offline Lee_dub
« Reply #23 on: 04 April 2008, 16:02 »
Ha Ha except im not as fit as that blond bird from blue peter.....
If i was her id never come out of my room  :evil:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #24 on: 04 April 2008, 21:21 »
^^^^^ Not at all mate, the peice that sits at the back of the headlight is held on with three of them split pin things, you need to remove the bumper to get to it because its below the headlight, how would u get to that?
As anyone else fitted this? and what did you do? im sure Rhys has fitted it and he removed the bumper....
Forgot about that!  I had the wheel arch liner off because I had just removed the VIS, so got at the bottom clip from the other side.
ps  Good way to get those clips out, incidentally, is to push through the back of them with a smallish torx bit, I found!!  :afro:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Lee_dub
« Reply #25 on: 04 April 2008, 21:50 »
Yea you have to knock the middle out first before you can remove the pin
Offline the_stink
  • A3 140 TDI
« Reply #26 on: 05 April 2008, 11:27 »
oke up this morning and the intake has arrived!!! less than 24 hours!!  :grin:
Offline Lee_dub
« Reply #27 on: 06 April 2008, 14:32 »
Get it on there lad and see if you agree with me!
